The Pi Hut
UB020201
Raspberry PI 3 B+ & Motioneye software
I can not get a resolution Higher than 640x480 no matter what settings I set in the Motioneye software.
I’ve tried it on a Mac and get the full 1920x1080 so I know the camera is not faulty
even when I load into Raspberry Pi OS I still only get the lower resolution.
Any help in solving this issue would greatly appreciated.
Please be aware I’m quite new to all this so may not understand everything you may suggest.
I do have another USB camera that shoots 1080p in Motioneye but the quality isn’t as good as this camera, maybe there is more compression from that camera.
This is the motion log with the UB020201 camera
[0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /data/etc/motion.conf
[0:motion] [NTC] [ALL] config_camera: Processing camera config file camera-1.conf
[0:motion] [NTC] [ALL] motion_startup: Logging to syslog
[0:motion] [NTC] [ALL] motion_startup: Motion 4.2.2+gitUNKNOWN Started
[0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
[0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN) [1:ml1:Camera1] [WRN] [VID] v4l2_pixfmt_set: Adjusting resolution from 1920x1080 to 640x480.
and the motion log with my other camera.
