Hi everyone, hoping someone here can help me out. I’ve got an Arducam Time-of-Flight Camera (B0410) and I’m trying to use it with the Arducam 10-meter Cable Extension Kit (U6248). The camera is connected to a Raspberry Pi 3 Model B+, and I’ve also tried it on a Pi 4 Model B — same result on both.
The problem: all I’m getting is static. Just noisy, frozen static on the screen. No depth data, no proper image, nothing. The camera works fine when connected directly without the extension kit, so the camera itself isn’t dead.
Has anyone successfully used the U6248 extension kit with the ToF camera? I’m starting to think these two aren’t actually compatible, even though the product page says they are.
I’ve got the video ribbon cable running from the camera to the U6248 board, and then the long cable from the U6248 board to the Pi’s camera port. But I wasn’t sure about power — the ToF camera has its own separate power input port, and I noticed the U6248 board doesn’t seem to have a power output for that. So right now the camera’s power port isn’t connected to anything. I figured maybe the extension kit handled power differently, but… clearly something’s wrong.
Thanks for the photo — that confirms exactly what I suspected, and it explains the static you’re seeing.
There are actually several hardware incompatibilities here, and I want to be upfront: the product listing on our site stating that the U6248 is compatible with the B0410 ToF camera is an oversight on our end. Here’s the breakdown:
1. Missing power port on the U6248 board
The Time-of-Flight camera requires separate power — it has both a video ribbon cable port and a dedicated power input port. The U6248 adapter board only passes through the video signal. It has no power output port at all. Without power reaching the camera, you’ll get exactly what you’re seeing: static, because the sensor isn’t actually running.
The workaround is that the U6248 board does have spots where you can solder pin headers to inject power. This is documented in our wiki — you solder the headers and supply power through those. But it’s not a plug-and-play solution out of the box.
2. Power cable too short
Even if you solder the pin headers, the power cable included in the U6248 kit is way too short to reach from the adapter board to the ToF camera’s power port in this configuration. This is another oversight in the kit design — the cable length was clearly specced for different camera models. You’ll need to source or make a longer power cable yourself.
3. Mounting hole mismatch
Physical mounting is also a problem. The ToF camera (B0410) has screw holes spaced at 30 mm, while the U6248 board uses 21 × 12.5 mm spacing. The holes don’t align at all, so you can’t screw them together directly.
Our engineering team is aware of these issues and is discussing board size compatibility for future revisions, but as of right now there is no extension kit purpose-built for the ToF camera.
For now, your path forward is:
Solder pin headers to the U6248 board for power delivery
Source a longer power cable to bridge the distance
Figure out a mechanical mounting solution — a custom 3D-printed adapter plate is probably the most practical option
Let me know if you want to proceed with any of that and I can point you to the relevant documentation.
Alright, that all makes sense — thanks for the detailed explanation. Disappointing that it’s listed as compatible when it clearly isn’t plug-and-play, but I’m willing to work around it.
I’ll solder the pin headers onto the U6248 board and make up a longer power cable myself, that part I can handle.
Question on the mechanical side though: does Arducam happen to have a 3D print file available — something like an adapter plate that would let me screw the ToF camera and the U6248 board together? The 30 mm vs 21 × 12.5 mm mismatch basically means I’m going to need some kind of bracket or adapter. Would rather not design one from scratch if there’s already an STL out there.
Good to hear you’re up for tackling the soldering and cable side of things.
Unfortunately, no — we don’t have an official STL or 3D print file for an adapter that bridges the ToF camera and U6248 board. Nothing exists, and there isn’t one currently in the pipeline either.
That said, if you do go ahead and design one yourself (which sounds like the plan), I can provide you with the exact hole-spacing dimensions and board outline measurements for both the B0410 and the U6248. Just let me know and I’ll get those over to you — should save you the hassle of reverse-engineering everything with calipers.
So to summarise where things stand:
Pin headers soldered + longer power cable = power issue solved
