Amazon.com - Model number of the product(s)?
B0251 - What hardware/platform were you working on?
Jetson Xavier NX Dev Kit, Jetpack 4.6.2, L4T 32.7.2 - Instructions you have followed. (link/manual/etc.)
IMX477 - Toubleshoot - Arducam - Problems you were having?
The jetson-io,py tool doesn’t seem to switch from default IMX219 driver to desired IMX477 driver - The dmesg log from your hardware?
dmesg shows IMX219 driver is installed, no mention of arducam or IMX477 - Troubleshooting attempts you’ve made?
have attempted to use the arducam driver installation script (./install_full.sh -m imx477)
It seems to work, and gets to the reboot. However, there is no sign that the driver is enabled.
I have attempted to use the jetson-io.py tool, and it seems to make no change. - What help do you need?
Any help to figure out how to get the IMX477 working would be great. Please be as pedantic/explicit as possible. Thank you very much.
~$ dmesg | grep -E “imx477|imx219|arducam”
[ 4.681633] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.705206] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.705316] imx219 9-0010: board setup failed
[ 4.705406] imx219: probe of 9-0010 failed with error -121
[ 4.705745] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.729056] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.729151] imx219 10-0010: board setup failed
[ 4.729212] imx219: probe of 10-0010 failed with error -121
The link below may help solve the problem you are encountering:
