Hi everyone, I’m trying to install an Arducam camera on my Jetson and I keep hitting an error during the install. I’ve taken a screenshot of what comes up. Hopefully someone has seen this before.
Welcome! Could you share a bit more about your setup? Which Jetson board are you using, and can you post the error screenshot so we can see what’s happening?
I’m on an NVIDIA Jetson Orin, specifically the AGX Orin dev kit. Here’s the error I’m getting: https://cdn.arducam.com/forum/0e2b13787124090b83a16ca0acb4c0a2/1000310513.jpg
Thanks for the screenshot. Before we dig into the install errors, the first thing to check is whether your Arducam camera model is actually on the supported list for the NVIDIA Jetson AGX Orin Development Kit. A lot of install failures on Orin come from trying to use a camera that isn’t supported for that particular carrier/board combination.
Where can I find the supported list? I assumed the camera would work since it’s an Arducam Jetson camera.
The official list is in the Arducam docs here: Introduction to Arducam Jetson Cameras - Arducam Wiki . Check that page and confirm your specific camera model is listed under the AGX Orin dev kit section. If it’s not listed there, that’s very likely the source of the install problem, and we’d need to verify compatibility before continuing with the install troubleshooting.
