ToF camera CSI data noise/static on Jetson Orin Nano with Arducam kernel
Hi, I’m having trouble getting my ToF camera to work properly on the Jetson Orin Nano. The camera opens fine via I2C — I can read/write registers without issues — so the driver seems to load correctly. But when I try to capture data, I’m just getting noise and static. No usable depth data at all. I’ve seen some other users mention something about an “interlacing” issue — could that be related? Any ideas what might be going on?
Thanks for reaching out. The fact that I2C communication is working is a good sign — it means the driver and system environment are likely configured correctly at the software level. The noise/static you’re seeing in the CSI data suggests the issue is probably at the hardware layer, specifically with the high-speed MIPI signal transmission. Before we dig into software debugging, let’s rule out a physical connection problem. Could you provide clear, high-resolution photos of:
  1. The camera side — how the ribbon cable is seated into the ToF camera module
  2. The Jetson side — the connection to the Orin Nano carrier board, showing which port you’re using and the orientation of the gold fingers on the cable
This will help me verify the hardware setup first.
Sure, I’ve attached the photos. The camera is connected to CAM1 on the carrier board. One thing I wanted to ask though — I’m currently powering the ToF camera through the Jetson’s GPIO pins: Pin 2 (5V) and Pin 6 (GND). I’m using some jumper wires to connect to the camera’s power connector. Is that sufficient, or do I need an external 5V/2A power source instead? I just assumed the GPIO 5V pin would be enough.
Thanks for the photos and details. Looking at the setup — while the Jetson GPIO Pin 2 does provide 5V, using long jumper wires to route power to the ToF camera can be problematic. Those wires introduce resistance, which can cause voltage drops — especially during the high-current pulses required by the camera’s illumination laser. That voltage drop under load could absolutely cause the noise/static you’re seeing in the CSI data.
Here’s what I’d like you to check before we go any further:
  1. Grab a multimeter and measure the voltage exactly at the pins of the white connector on the camera board (not at the Jetson end).
  2. Check the idle voltage — just with the camera plugged in, before running any capture.
  3. Then run the camera capture command and monitor the voltage at that same point under load.
If the voltage stays at a stable 5V (±5%) during capture, then GPIO power is fine and we’ll look elsewhere. But if it drops significantly — say to 4.7V or lower — that confirms the GPIO source or the jumper wires can’t deliver enough current when the laser fires up. Let me know what you see.
Yeah, that was exactly it. I measured the voltage at the camera connector and it was sitting at around 4.9V idle, but as soon as I started the capture command it dropped to about 4.55V. Pretty clear voltage drop. I switched to an external 5V/2A power source using a buck converter (with a common ground shared to the Jetson), and now the camera captures clean depth data with no static! Issue seems to be fully resolved. Thanks so much for the help!
Great to hear that resolved it! Glad we tracked that down. To summarize for anyone else running into this: if you’re using GPIO power with jumper wires to run a ToF camera, the wire resistance can cause voltage drops under load (especially during the laser pulses), leading to noisy/static CSI data. The fix is to use a dedicated external 5V/2A power source with a common ground shared to the Jetson. Always measure the voltage at the camera board connector under load to confirm stability. Happy you’re getting clean data now!
