edul
May 27, 2021, 5:20am
1
Other - www.botland.com.pl
https://botland.store/raspberry-pi-cameras/16885-arducam-ov2311-2mpx-global-shutter-camera-module-for-raspberry-pi-noir-monochrome.html
https://botland.store/raspberry-pi-cameras/6128-raspberry-pi-noir-camera-hd-v2-8mpx-original-night-camera-for-raspberry-pi-640522710898.html
Linux
https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield
N/A
I’m trying to get valid timestamps for frames to later sync with other sensors in my system. Unfortunately ArduCamOutData struct field u64Time provides some random numbers.
Is it possible to get reasonable timestamp in CONTINUOUS_MODE? (Assigning timestamp after reading data from FIFO ArduCam_readImage is sub optimal imho)
My initial idea was to save timestamp when ArduCam_captureImage is called and later assign it to frame in image reading thread.
Please share your opinion and suggest solution for reasonable timestamping. Providing updated C/C++ documentation would also help.
wong
May 28, 2021, 2:23am
2
Hi @edul
Sorry, the current SDK does not provide a timestamp. You can get the system time when readingImage, but this method has an uncertain delay.
Next week, I will take a closer look at the SDK to find the best way to add timestamps.
wong
May 30, 2021, 7:54pm
3
HIi @edul ,
try this:
https://drive.google.com/file/d/1f18TwXnXLu0Q8eDEnE4t9Jvkl_TSrPD7/view
note: replace Arducam_SDK folder and execute make install_sdk
edul
May 30, 2021, 10:04pm
4
Hi @wong ,
Thanks for sharing this with me, I will test it and let you know.
Can you describe how(when) timestamps are assigned in this version?
edul
May 31, 2021, 5:45am
5
Hi @wong ,
With new version frame u64Time still provides random number. Could you provide some valid example you used for testing?
wong
May 31, 2021, 5:40pm
6
Maybe it was not replaced correctly?
This is my test result:
wong
May 31, 2021, 5:46pm
7
By the way, the unit of time is microseconds.
edul
June 1, 2021, 12:43am
8
I tried on few different sensors and it’s still doesn’t make sense.
Here is branch I used in tests https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield/compare/master…e-dul-xb:install_sdk_dev_timestamps
To be 100% sure I removed old libs and clean then install everything again.
dev@dev:/code/arducam_ws/ArduCAM_USB_Camera_Shield/Linux_x86/Cpp/Streaming_demo$ make clean
rm -f ArduCam_Demo
dev@dev:/code/arducam_ws/ArduCAM_USB_Camera_Shield/Linux_x86/Cpp/Streaming_demo$ sudo rm -rf /usr/lib/libArduCamLib.so*
dev@dev:/code/arducam_ws/ArduCAM_USB_Camera_Shield/Linux_x86/Cpp/Streaming_demo$ make install-sdk
sudo cp -d ./Arducam_SDK/lib*.so* /usr/lib
sudo cp ./Arducam_SDK/ArduCamLib.h /usr/include
dev@dev:/code/arducam_ws/ArduCAM_USB_Camera_Shield/Linux_x86/Cpp/Streaming_demo$ ls -lha /usr/lib/libArduCamLib.so*
lrwxrwxrwx 1 root root 22 Jun 1 07:28 /usr/lib/libArduCamLib.so -> libArduCamLib.so.2.0.0
lrwxrwxrwx 1 root root 22 Jun 1 07:28 /usr/lib/libArduCamLib.so.2 -> libArduCamLib.so.2.0.0
-rwxr-xr-x 1 root root 353K Jun 1 07:28 /usr/lib/libArduCamLib.so.2.0.0
Then compiled and run:
g++ ArduCam_Demo.cpp Arducam_SDK/ArduCamLib.h -o ArduCam_Demo -lArduCamLib -lusb-1.0 -lpthread -larducam_config_parser pkg-config --cflags --libs opencv -L. -I. -std=gnu++11 -g
dev@dev:/code/arducam_ws/ArduCAM_USB_Camera_Shield/Linux_x86/Cpp/Streaming_demo$ ./ArduCam_Demo …/…/…/Config/USB3.0_UC-425_Rev.C+UC-628_Rev.B/OV2311/OV2311_MIPI_2Lane_RAW8_8b_1600x1300_60fps.cfg
device num:4
index: 0 Serial:AU3S-2114-0002
index: 2 Serial:
index: 2 Serial:
index: 4 Serial:
Serial: AU3S-2114-0002
setFramerate not a function
capture thread create successfully.
read thread create successfully.
Capture began, rtn_val = 0
Gtk-Message: 07:28:57.716: Failed to load module “canberra-gtk-module”
time: 94227671415904
time: 15
time: 0
time: 94227671415760
time: 79
time: 0
time: 15
time: 0
time: 79
-------------------11 fps
time: 0
time: 15
time: 0
time: 79
time: 0
time: 15
time: 0
time: 79
time: 0
time: 15
time: 0
time: 79
time: 0
time: 15
time: 0
time: 79
time: 0
time: 15
time: 0
time: 79
time: 0
time: 15
time: 0
time: 79
time: 0
time: 15
time: 0
time: 79
time: 0
Any suggestions?
btw. going back to question from previous message: Can you describe how(when) timestamps are assigned in this version?
wong
June 1, 2021, 5:55pm
9
Hi @edul
I think I found my mistake, a part that I missed, this version should be correct:
https://drive.google.com/file/d/1KfoFNYBrC0tkvI4fFtDG7d3Hli3uQUhm/view
Regarding how timestamp is assigned:
This version of timestamps will be assigned the current time when a frame is received.
edul
June 2, 2021, 2:31am
10
Hi @wong ,
New version assigns reasonable timestamps, thank you.
In streaming demo it would look something like this?
This solution would aggregate USB communication related delays and jitter. Please correct me if I’m wrong.
On the other hand I would suggest to assign it earlier when capture starts, I think it would be more reasonable.
Please let me know what you think about it.
wong
June 2, 2021, 5:56pm
11
Hi @edul
Your sequence diagram is basically correct, except for the captureImage part, the captureImage part is not blocking, in fact it is handling libusb event processing.
https://libusb.sourceforge.io/api-1.0/group__libusb__poll.html
You are right, it can be done, I will conduct some simple tests.
wong
June 2, 2021, 7:03pm
12
You can try this version, I added a timestamp when I first received the data of a certain frame:
https://drive.google.com/file/d/1gJspFr9pG5vhrqPbXVwVVgflHsFOaBpd/view?usp=sharing
edul
June 7, 2021, 12:28am
13
Hi @wong
Thanks for update, I will try to test it and let you know how it works for me
