HI there,
I want to use the arducam on Jetson Linux 34.1.1 and NVidia NX, will this Jetpack to be supported soon?
hi, @xuhao3e8
We are already adapting JetPack 5.0 and 5.0.1.
At present, some problems have been encountered during the adaptation process. We also communicated with NVIDIA engineers, and now we can produce pictures, but the frame rate cannot reach the standard frame rate. If you don’t mind, we can give you a beta version first.
However, we still do not recommend using these two newer systems. Nvidia’s official description also mentioned that this is only a preview version and is not recommended for commercial use.
@yang Thanks for your reply again!
I would like to test it if it’s framerate may reach 20FPS because our other software are on 20.04.
hi, @xuhao3e8
We have released the Arducam driver installation package for L4T34.1.1 system. You can install it by installing the script.
Thanks! I will test it very soon.
