I’m trying to capture raw bayer frames from my IMX477 module i recently purchased. As far as I understand I need to bypass the internal ISP to do so, right ? Trying some examples always failed. In most cases, the v4l2-ctrl commands just freeze without any output. Weirdly enough getting processed frames using gstreamer works without any problems
Arducam - Model number of the product(s)?
B0249 - What hardware/platform were you working on?
Jetson Nano 4G on latest kernel with arducam driver - Instructions you have followed. (link/manual/etc.)
Capture Raw images from IMX477 with Nano - #2 by wong - Problems you were having?
python version fails to run due to problems with v4lc, the c version exits with “select timeout” - The dmesg log from your hardware?
[ 1.192609] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1 - Pastebin.com - Troubleshooting attempts you’ve made?
testing the nvidia and arducam driver and testing different v4l2-ctrl commands to get raw data - What help do you need?
