Well… this got worse. I wired the 6 dupont connectors according to the label printed on the board and powered everything up. There was smoke coming from the board and/or the cameras within seconds. I pulled power immediately.
Now when I run:
ls /dev/video0
It doesn’t register anything. The cameras are completely gone. No /dev/video0 at all.
I haven’t tried anything else yet — wanted to check here before I make things worse. Any ideas what happened and whether this board is salvageable?
Hi, thanks for the detailed report. I’ve looked into this and I can confirm — the label on your Multi-cam board is actually correct. The silkscreen is not misprinted.
What’s likely happening here is that the label on the board is indicating which pins on the HAT itself correspond to which signals — but the orientation of how the HAT mates with the Jetson GPIO header matters. If the dupont wiring was done pin-to-pin based on the label without accounting for the physical orientation of the HAT when attached to the Jetson, the 5V, 3V3, and GND lines can end up swapped, which would explain the smoke.
Can you take a look at the official wiring diagram here? It shows the correct way the HAT board attaches to the Jetson GPIO header:
I’m attaching a visual reference here that shows the correct HAT-to-Jetson GPIO header connection:
Notice the orientation — the HAT board sits on top of the Jetson GPIO header in a specific way, and the pin mapping follows that physical layout. The label on the board makes sense once you account for this.
Ah… yeah, I see it now. I completely misinterpreted how the board orients on the GPIO header, and I ended up wiring the dupont connectors in a way that sent 5V where it shouldn’t have gone. That explains the smoke.
That’s on me — the label is fine, my wiring was not. Thanks for the diagram, that clears it up. Now I need to figure out whether my board and cameras survived the incident. Since /dev/video0 isn’t showing up, I’m guessing something got fried. Appreciate the quick help.
