arducam site -
64mp arducam -
rpi4b -
all installed -
skpped frames when:
libcamera-vid -t 0 --inline --height 720 --width 1280 --autofocus -o udp://ipaddress:3333
Preview window unavailable
[1:09:43.483226383] [1096] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[1:09:43.539037892] [1098] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[1:09:43.539085650] [1098] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[1:09:43.539379624] [1098] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
Open i2c bus error: No such file or directory
[1:09:43.553797539] [1098] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[1:09:43.554384838] [1098] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[1:09:43.554567370] [1098] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media2
[1:09:43.555181130] [1096] INFO Camera camera.cpp:1029 configuring streams: (0) 1280x720-YUV420
[1:09:43.555533399] [1098] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 1280x720-SBGGR10_1X10 - Selected unicam format: 1280x720-pBAA
vlc udp://@:3333
40001610] udp stream error: 5739 bytes packet truncated (MTU was 5137)
[00007f2840001610] udp stream error: 6222 bytes packet truncated (MTU was 5739)
[00007f2840001610] udp stream error: 6269 bytes packet truncated (MTU was 6222)
[00007f2840001610] udp stream error: 6741 bytes packet truncated (MTU was 6269)
[00007f2840001610] udp stream error: 6885 bytes packet truncated (MTU was 6741)
[00007f2840001610] udp stream error: 6945 bytes packet truncated (MTU was 6885)
[00007f2840001610] udp stream error: 7464 bytes p
dmesg | grep cam
[ 6.554455] arducam_64mp: loading out-of-tree module taints kernel.
[ 6.573219] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 6.573925] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[ 31.710839] cam-dummy-reg: disabling
Any way to tweak to avoid skpped frame every couple seconds?
