UCtronics.com -
Arducam IMX219-AF Programmable/Auto Focus Camera Module for NVIDIA Jetson Nano -
Jetson Nano -
Successfully ran Autofocus.py at ArduCAM repo -
I found a good focus value using this python program. I noted that the i2cset command to get this focus wasi2cset -y 6 0x0c 21 224
, however when running this i2cset command from my c++ program, I noticed the focus actually got worse. -
NA -
Modified my program to set the focus in different ways -
Why does the focus end up worse when I run the same focus command?
Also, what should the ideal focus value be for a target 6.5 inches away? It seems the python program is using values from 10 to 1000. What do these correspond to in real world distances?
Thanks!
