Scoprion Vision, UK
U
RPi 4 32 bit Linux
Reading C code
This feature has not worked
I’m trying to set the lens table of an UC-572 camera with the following code:
int ArduGrab::initCamera() {
int res;
log(“init camera”);
if (!cameraConnected) {
if (!this->sim) {
res = arducam_init_camera(&this->camera_instance);
if (res) {return -1;}
string str = “/home/pi/ArduGrab/imx298/ls_table_4656x3496.h”;
log("setting lens table from " + str);
char *path = new char[str.length() + 1];
strcpy(path, str.c_str());
arducam_set_lens_table(camera_instance, path);
delete [] path;
res = arducam_set_mode(camera_instance, 4);
cameraConnected = true;
log(“init camera done”);
return 0;
However, this isn’t working, the output when testing this is:
pi@raspberrypi:~/ArduGrab $ ./run-c+±test.sh
set debug true
set sim false
init camera
Found sensor imx298 at address 1A
setting lens table from /home/pi/ArduGrab/imx298/ls_table_4656x3496.h
Just to check that we are pointing to the correct file:
pi@raspberrypi:~/ArduGrab $ ls -al /home/pi/ArduGrab/imx298/ls_table_4656x3496.h
-rw-r–r-- 1 pi pi 14348 Jun 15 17:39 /home/pi/ArduGrab/imx298/ls_table_4656x3496.h
Can you help advise as to the reason from the problem please?
Thanks.
Regards,
Neil
Wrriten code and debugged it
advise on settign lens table
