Welectronics
Arducam IMX298 MIPI 16MP Color Camera Module for Raspberry Pi 4/3B+/3
Raspberry Pi 3B+
Github sdk library examples
Yes it works.
I´m writting an application on python that needs to run 24/7 reading some aruco markers with openCV and writting those id´s on an mysql server.
I based my code on the example capture2opencv.py, i´m using mode 2 and the image runs at about 2fps but that is not the main problem.
my 2 main problems are the following:
1.- Watching the code run for a long period of time i randomly get a Valuerror at the moment i try to use the method camera.capture(), i implemented a try-except block catching that error re-asigning the camera object and re-setting the controls (exposure, awb, etc). Sometimes it works but most of the time just keeps failing and crashes the program.
2.- When the camera doesn´t return this ValueError after about a day i get a segmentation fault crashing again the program
I attach an image of the problems i get.
Implementing some try-except and reconfiguring the camera object.
Some possible solutions to my 2 problems so that i can get the code running indifinetly
