Seeking board for daisy-chaining 80 64MP MIPI camera modules with 10Gbps LVDS/Ethernet and local storage
Hi everyone, I’m working on a modular camera architecture and could really use some direction. The plan is to daisy-chain roughly 80 camera modules together. Each module would have a 64MP MIPI camera connected to a bridge IC that converts MIPI CSI-2 to LVDS or Ethernet, with at least a 10Gbps interface. Each module would also have a uSD card for local storage to temporarily hold image data. The bridge IC would store captured images to local memory, communicate with the other camera modules to retrieve image data from their local memory, and then transfer the image data over LVDS/Ethernet to a server. I’ve looked at Arducam’s long-distance communication option, but it only goes up to about 10 meters, so I’m trying to find a better alternative. Has anyone built something like this?
Thanks for the clear description. The bridge selection is going to be the make-or-break part of a chain that size. Can you share which cameras and modules you’re evaluating? Arducam has several MIPI CSI-2 converters/bridges to other interfaces that might be relevant depending on the link you pick. Also, what distance are you targeting per hop and end-to-end? The 10m figure you mentioned is the limit for their long-distance option, so that target will drive which interface makes sense.
Sure. For the feasibility study I’ve already bought several of Arducam’s 64MP MIPI CSI-2 cameras and one of the 64MP quad camera kits. Here’s what I’m working with:
Got it. The 64MP modules should be fine as the image source for a proof of concept. The part that’s still open is the bridge — sustaining ≥10Gbps over LVDS or Ethernet while daisy-chaining that many nodes is the piece that doesn’t have an off-the-shelf answer yet. I’d suggest validating one module first (camera → local memory → uSD) so you can separate the camera side from the link/bridge side before committing to the full chain.
One more question while I’m setting up that single-module test: can the Arducam 64MP MIPI CSI-2 camera be interfaced with a Raspberry Pi Zero 2 W? I’d like to use the Zero 2 W as the host for the feasibility tests: https://www.raspberrypi.com/products/raspberry-pi-zero-2-w/
You can use the 64MP camera with the Pi Zero W — the Zero 2 W uses the same MIPI CSI-2 camera connector, so that’s fine for bring-up and single-camera capture. Just keep in mind the Pi is only the test host here; the bridge IC is what handles the local storage and the LVDS/Ethernet transfer for the full chain. To summarize: 64MP module compatibility with the Pi Zero W is confirmed, and the broader architecture question — the ≥10Gbps bridge, the ~80-module daisy chain, and the >10m distance — is still open and needs to be validated against the converter/bridge options on the page linked above.
