Save image on PC from Raspberry Pico and OV5642
I am trying to save a still on my PC from the Arducam 5MP Plus OV5642 connected to a Raspberry Pico. The camera works fine and when I use HostApp.exe I can capture with no problems. Now I am trying to save a still on my computer using Python. So far I can communicate, and send the trigger signal to capture, then I can see the buffer coming back in hex, but I am having troubles formatting it properly. This is the code I have so far, and bellow the current error. Thanks for any help!
import serial
from binascii import unhexlify
s = serial.Serial('COM9', 115200)
# Set resolution
command = "06"
command = unhexlify(command)
s.write(command)
# Grab still
command = "10"
s.write(command)
currByte = b""
buffer = []
while True:
    if s.isOpen():
        line = s.readline().strip()
        print(line)
        currByte = unhexlify(b'0' + line)
s.close()
  File "E:/envs/camcontrol/camcontrol.py", line 23, in <module>
binascii.Error: Odd-length string
b'\xff\xd8\xff\xe0\x00\x10JFIF\x00\x01\x01\x01\x00\x00\x00\x00\x00\x00\xff\xdb\x00C\x00\x04\x03\x03\x04\x03\x03\x04\x04\x03\x04\x05\x04\x04\x05\x06'
Process finished with exit code 1
So, it seems no one is listening but I will keep updating this thread in case anyone finds it useful. Kind of Robinson Crusoe but without the nice beach.
I learned that I am receiving a JPEG (hence the JFIF above) and that FF and D8 is the header. Also that I need to find the end/trailer which comes as FF and D9. Now the problem is that of the many times I tried to find those FF and D9, only once I found them. It seems I am not sending the right command to retrieve, or maybe I have to do something else after sending the capture command b’\x10’. I will keep digging and spotting the horizon here and there in case some ship passes by.
while True:
    if s.isOpen():
        out_hex = ['{:02X}'.format(b) for b in line]
        h_temp = ""
        print(line)
        for h in out_hex:
            if h_temp == "FF" and h == "D9":
                print(line)
                break
Hello, again my dear readers. I made more progress, now I can save the data from Arducam/Pico to a jpg and it works. Sometimes. Most of the times if set to low resolution. Only some times if I set the resolution higher. As proof I send you one of the jpgs that I proudly saved:
This is the code that I used for this first partial success, I am reading in chunks of 128 bytes:
import serial
import binascii
s = serial.Serial('COM9', 921600)
# Set resolution
command = b'\x05'
s.write(command)
# Grab still
command = b'\x10'
s.write(command)
data = ""
stop = 0
while True:
    if s.isOpen():
        lines = s.read(128)
        out_hex = ['{:02X}'.format(b) for b in lines]
        # print(out_hex)
        h_temp = ""
        for h in out_hex:
                data += h
                stop = 1
                print("Found footer")
                break
            else:
                data += h
                h_temp = h
    if stop == 1:
        break
data_b = binascii.a2b_hex(data)
with open(r"buffer.jpg", "wb") as f:
    f.write(data_b)
I think I might be skipping some step to clear the buffer, or maybe I just have to make the process wait at some point so it has time to receive all the data and that is why it fails many times.
Long ago I found that patience is a virtue. Arducam feels the same. Just add a stop between the call to the resolution setting and the grab and it finally works perfectly!
import serial
import binascii
import time
# Set resolution
command = b'\x05'
s.write(command)
time.sleep(1)
# Grab still
command = b'\x10'
s.write(command)
data = ""
stop = 0
while True:
    if s.isOpen():
        lines = s.read(128)
        # print(out_hex)
        h_temp = ""
        for h in out_hex:
                data += h
                stop = 1
                break
            else:
                data += h
                h_temp = h
    if stop == 1:
        break
    f.write(data_b)
Hi i just want to thank you, cause your code help me to much to control the camera with out the .exe of arducam, i am bulding my proyect to get my degree of engineering
I am happy it worked out for you too! I ended up sync linking 12 cams to shot at the same time to later reconstruct in 3d. What is your project about? Un abrazo!
your project sounds very interesting,
we used it to build a low cost dermatoscope, for analizing moles with AI looking for skin cancer, i am working with a classmate
Thank you so much for sharing this @Carlos. This is the only place I’ve found someone with the exact same issue I am having after days of searching and debugging frantically. I am about to try and really hope it works for me too.
Thank you!!
Hi, I’m trying to do the same here. I was just wondering what code you had on the Pico side?
It’s been a while since I don’t use this, but it worked at the time. I used it to have 12 arducams+pico grab a picture sync at the same time:
import time as utime
import busio
import board
import usb_cdc
from Arducam import *
from board import *
import math
mode = 0
start_capture = 0
stop_flag=0
once_number=128
value_command=0
flag_command=0
buffer=bytearray(once_number)
mycam = ArducamClass(OV5642)
mycam.Camera_Detection()
mycam.Spi_Test()
mycam.Camera_Init()
mycam.Spi_write(ARDUCHIP_TIM,VSYNC_LEVEL_MASK)
utime.sleep(1)
mycam.clear_fifo_flag()
mycam.Spi_write(ARDUCHIP_FRAMES,0x00)
def read_fifo_burst():
    count=0
    lenght=mycam.read_fifo_length()
    mycam.SPI_CS_LOW()
    mycam.set_fifo_burst()
    while True:
        mycam.spi.readinto(buffer,start=0,end=once_number)
        usb_cdc.data.write(buffer)
        utime.sleep(0.00015)
        count+=once_number
        if count+once_number>lenght:
            count=lenght-count
            mycam.spi.readinto(buffer,start=0,end=count)
            mycam.SPI_CS_HIGH()
            break
st = utime.time()
et = math.ceil(st)
while True:
    if utime.time() > et:
        if usb_cdc.data.in_waiting > 0:
            value_command = usb_cdc.data.read()
            flag_command=1
        if flag_command==1:
            flag_command=0
            value=int.from_bytes(value_command,"big")
            if value== 0:
                mycam.OV5642_set_JPEG_size(OV5642_320x240)
            elif value== 1:
                mycam.OV5642_set_JPEG_size(OV5642_640x480)
            elif value== 2:
                mycam.OV5642_set_JPEG_size(OV5642_1024x768)
            elif value== 3:
                mycam.OV5642_set_JPEG_size(OV5642_1280x960)
            elif value== 4:
                mycam.OV5642_set_JPEG_size(OV5642_1600x1200)
            elif value== 5:
                mycam.OV5642_set_JPEG_size(OV5642_2048x1536)
            elif value== 6:
                mycam.OV5642_set_JPEG_size(OV5642_2592x1944)
            elif value== 0x10:
                mode = 1
                start_capture = 1
            elif value== 0x20:
                mode = 2
                start_capture = 2
                stop_flag=0
            elif value== 0x21:
                stop_flag=1
            elif value== 0x40:
                mycam.OV5642_set_Light_Mode(Advanced_AWB)
            elif value== 0x41:
                mycam.OV5642_set_Light_Mode(Simple_AWB)
            elif value== 0x42:
                mycam.OV5642_set_Light_Mode(Manual_day)
            elif value== 0x43:
                mycam.OV5642_set_Light_Mode(Manual_A)
            elif value== 0x44:
                mycam.OV5642_set_Light_Mode(Manual_cwf)
            elif value== 0x45:
                mycam.OV5642_set_Light_Mode(Manual_cloudy)
            elif value== 0x50:
                mycam.OV5642_set_Color_Saturation(Saturation4)
            elif value== 0x51:
                mycam.OV5642_set_Color_Saturation(Saturation3)
            elif value== 0x52:
                mycam.OV5642_set_Color_Saturation(Saturation2)
            elif value== 0x53:
               mycam.OV5642_set_Color_Saturation(Saturation1)
            elif value== 0x54:
                mycam.OV5642_set_Color_Saturation(Saturation0)
            elif value== 0x55:
                mycam.OV5642_set_Color_Saturation(Saturation_1)
            elif value== 0x56:
                mycam.OV5642_set_Color_Saturation(Saturation_2)
            elif value== 0x57:
                mycam.OV5642_set_Color_Saturation(Saturation_3)
            elif value== 0x58:
                mycam.OV5642_set_Light_Mode(Saturation_4)
            elif value== 0x60:
                mycam.OV5642_set_Brightness(Brightness4)
            elif value== 0x61:
                mycam.OV5642_set_Brightness(Brightness3)
            elif value== 0x62:
                mycam.OV5642_set_Brightness(Brightness2)
            elif value== 0x63:
                mycam.OV5642_set_Brightness(Brightness1)
            elif value== 0x64:
                mycam.OV5642_set_Brightness(Brightness0)
            elif value== 0x65:
                mycam.OV5642_set_Brightness(Brightness_1)
            elif value== 0x66:
                mycam.OV5642_set_Brightness(Brightness_2)
            elif value== 0x67:
                mycam.OV5642_set_Brightness(Brightness_3)
            elif value== 0x68:
                mycam.OV5642_set_Brightness(Brightness_4)
            elif value== 0x70:
                mycam.OV5642_set_Contrast(Contrast4)
            elif value== 0x71:
                mycam.OV5642_set_Contrast(Contrast3)
            elif value== 0x72:
                mycam.OV5642_set_Contrast(Contrast2)
            elif value== 0x73:
                mycam.OV5642_set_Contrast(Contrast1)
            elif value== 0x74:
                mycam.OV5642_set_Contrast(Contrast0)
            elif value== 0x75:
                mycam.OV5642_set_Contrast(Contrast_1)
            elif value== 0x76:
                mycam.OV5642_set_Contrast(Contrast_2)
            elif value== 0x77:
                mycam.OV5642_set_Contrast(Contrast_3)
            elif value== 0x78:
                mycam.OV5642_set_Contrast(Contrast_4)
            elif value== 0x80:
                mycam.OV5642_set_hue(degree_180)
            elif value== 0x81:
                mycam.OV5642_set_hue(degree_150)
            elif value== 0x82:
                mycam.OV5642_set_hue(degree_120)
            elif value== 0x83:
                mycam.OV5642_set_hue(degree_90)
            elif value== 0x84:
                mycam.OV5642_set_hue(degree_60)
            elif value== 0x85:
                mycam.OV5642_set_hue(degree_30)
            elif value== 0x86:
                mycam.OV5642_set_hue(degree_0)
            elif value== 0x87:
                mycam.OV5642_set_hue(degree30)
            elif value== 0x88:
                mycam.OV5642_set_hue(degree60)
            elif value== 0x89:
                mycam.OV5642_set_hue(degree90)
            elif value== 0x8a:
                mycam.OV5642_set_hue(degree120)
            elif value== 0x8b:
                mycam.OV5642_set_hue(degree150)
            elif value== 0x90:
                mycam.OV5642_set_Special_effects(Normal)
            elif value== 0x91:
                mycam.OV5642_set_Special_effects(BW)
            elif value== 0x92:
                mycam.OV5642_set_Special_effects(Bluish)
            elif value== 0x93:
                mycam.OV5642_set_Special_effects(Sepia)
            elif value== 0x94:
                mycam.OV5642_set_Special_effects(Reddish)
            elif value== 0x95:
                mycam.OV5642_set_Special_effects(Greenish)
            elif value== 0x96:
                mycam.OV5642_set_Special_effects(Negative)
            elif value== 0xA0:
                mycam.OV5642_set_Exposure_level(Exposure_17_EV)
            elif value== 0xA1:
                mycam.OV5642_set_Exposure_level(Exposure_13_EV)
            elif value== 0xA2:
                mycam.OV5642_set_Exposure_level(Exposure_10_EV)
            elif value== 0xA3:
                mycam.OV5642_set_Exposure_level(Exposure_07_EV)
            elif value== 0xA4:
                mycam.OV5642_set_Exposure_level(Exposure_03_EV)
            elif value== 0xA5:
                mycam.OV5642_set_Exposure_level(Exposure_default)
            elif value== 0xA6:
                mycam.OV5642_set_Exposure_level(Exposure07_EV)
            elif value== 0xA7:
                mycam.OV5642_set_Exposure_level(Exposure10_EV)
            elif value== 0xA8:
                mycam.OV5642_set_Exposure_level(Exposure13_EV)
            elif value== 0xA9:
                mycam.OV5642_set_Exposure_level(Exposure17_EV)
            elif value== 0xB0:
                mycam.OV5642_set_Sharpness(Auto_Sharpness_default)
            elif value== 0xB1:
                mycam.OV5642_set_Sharpness(Auto_Sharpness1)
            elif value== 0xB2:
                mycam.OV5642_set_Sharpness(Auto_Sharpness2)
            elif value== 0xB3:
                mycam.OV5642_set_Sharpness(Manual_Sharpnessoff)
            elif value== 0xB4:
                mycam.OV5642_set_Sharpness(Manual_Sharpness1)
            elif value== 0xB5:
                mycam.OV5642_set_Sharpness(Manual_Sharpness2)
            elif value== 0xB6:
                mycam.OV5642_set_Sharpness(Manual_Sharpness3)
            elif value== 0xB7:
                mycam.OV5642_set_Sharpness(Manual_Sharpness4)
            elif value== 0xB8:
                mycam.OV5642_set_Sharpness(Manual_Sharpness5)
            elif value== 0xC0:
                mycam.OV5642_set_Mirror_Flip(MIRROR)
            elif value== 0xC1:
                mycam.OV5642_set_Mirror_Flip(FLIP)
            elif value== 0xC2:
                mycam.OV5642_set_Mirror_Flip(MIRROR_FLIP)
            elif value== 0xC3:
                mycam.OV5642_set_Mirror_Flip(Normal)
            elif value== 0xD0:
                mycam.OV5642_set_Compress_quality(high_quality)
            elif value== 0xD1:
                mycam.OV5642_set_Compress_quality(default_quality)
            elif value== 0xD2:
                mycam.OV5642_set_Compress_quality(low_quality)
            elif value== 0xE0:
                mycam.OV5642_Test_Pattern(Color_bar)
            elif value== 0xE1:
                mycam.OV5642_Test_Pattern(Color_square)
            elif value== 0xE2:
                mycam.OV5642_Test_Pattern(BW_square)
            elif value== 0xE3:
                mycam.OV5642_Test_Pattern(DLI)
        if mode==1:
            if start_capture==1:
                mycam.flush_fifo();
                mycam.clear_fifo_flag();
                mycam.start_capture();
                start_capture=0
            if mycam.get_bit(ARDUCHIP_TRIG,CAP_DONE_MASK)!=0:
                read_fifo_burst()
                mode=0
        if mode==2:
            if stop_flag==0:
                if start_capture==2:
                    start_capture=0
                    mycam.flush_fifo();
                    read_fifo_burst()
                    start_capture=2
            else:
                mode=0
                start_capture=0
Bonjour vous allez bien j’espere je suis nouveau je lisais et je suis tombé sur votre projet. Aussi j’ai un projet qui n’est pas trop different du votre. je voulais une assistance
merci
