Hi @BamBam
Could you stream the imx462 camera on your Pi Zero 2W while getting this error?
Iām not sure what you are asking but the libcamera-still above usually gives me a second steam on the screen. I just tried libcamera-vid and got the same error.
Hi @BamBam
You can completely ignore this error log. Weāve already burned the turning file into the cameraās firmware. The libcamera software will output this error cause it doesnāt find the appropriate turning file for the IMX462 camera from this directory. As I said, the turning file is already integrated into the firmware, the libcamera actually applies it when we use libcamera commands(including libcamera-still/libcamera-vid, etc).
What I asked is if you could get the camera preview when you run the command like libcamera-still -t 0 though the libcamera output the error log arducam-pivariety.jsonā not found for IPA module ārpl/vc1ā.
Hi, Iām trying to use the IMX462 camera module with my Raspberry Pi 3 Model B, but Iām having trouble getting it to work.
After connecting the camera to the CSI port and enabling I2C via raspi-config, the system still does not detect the camera (nothing under /dev/video*). I followed the steps from the official guide, including the firmware update.
I tried running the following commands:
sudo ./firmware_update -m sku_b0444 -i 1
sudo ./firmware_update -m sku_b0444 -i 2
sudo ./firmware_update -m sku_b0444 -i 4
sudo ./firmware_update -m sku_b0444 -i 10
But all of them result in errors such as:
/dev/i2c-x: File does not exist
Failed to read sensor ID
Write update flag 2 error
I also ran i2cdetect -y 1 and confirmed that no I2C devices are detected on bus 1.
At this point, Iām not sure if the camera module is compatible with Raspberry Pi 3, or if the CSI port might be damaged. Has anyone successfully used the IMX462 with Raspberry Pi 3? Any suggestions on what I should check next?
Thanks in advance!
ā
I have two IMX462ās working with rPi 3a using the latest bookworm lite image. I did apply the firmware update using -i 10, ensure that you enable i2c using raspi-config and reboot. I also added dtoverlay=arducam-pivariety in /boot/firmware/config.txt.
I am running a 32bit installation from May 13th 2025 on a Zero 2 W. I do get the same message as above (although it says rpl/vc4, not rpl/vc1). I can confirm that I do not get the camera preview when I run the command above.
In contrast to what @Dion has written here
I did run the respective commands.
Apparenty, firmware is 0x10003. Update is not possible as it returns
[ERROR] /dev/i2c-4: File does not exist.
when called from within archive/output/armv7l/sku_b0444/
libcamera-vid --list-cameras returns
0: arducam-pivariety [1920x1080 10-bit RGGB] (/base/soc/i2c0mux/i2c@1/arducam_pivariety@c)
Modes: āSRGGB10_CSI2Pā : 2147485568x1080 [30.00 fps - (65536, 65536)/65536x65636 crop]
Please adivse.
Please try the following command:
Moreover, please ensure that youāve already enabled the i2c interface in the raspi-config.
Thank you, firmware update worked.
For libcamera-still -t 0 I get an image but also an error:
[ERROR] IPAProxy ipa_proxy.cpp:171 Configuration file āarducam-pivariety.jsonā not found for IPA module ārpi/vc4ā
and
[WARN] RPiSdn snd.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
In general, I will monitor performance, both for low light and framerate, closely.
Please refer to the discussion in the following thread.
Ok. Iāll follow that. Do I also need to follow the troubleshooting guide I found that says to either disable the UART or adjust speed? Iām using Bluetooth for initially setting my WiFi which I think needs UART.
I was also confused with your installer. I noted there are several versions of the libcam modules that ends in _bookworm. Do I need those? Or follow the QuickStart guide that says to install libcam_dev and libcam_apps
No, you donāt.
Just go ahead. The installation script is designed for both Bullseye and Bookworm. Thatās why we keep libcamera_dev and libcamera_apps.
While the Raspberry Pi Foundation has discontinued the libcamera software link, the framework is still the libcamera library.
The sudo apt install libtinfo5 no longer works, this allowed me to run the firmware update on a pi4 with 64-bit trixie.
wget https://launchpad.net/ubuntu/+archive/primary/+files/libtinfo5_6.3-2ubuntu0.1_arm64.deb
sudo dpkg -i libtinfo5_6.3-2ubuntu0.1_arm64.deb
sudo apt-get -f install # to fix deps if needed
