For:
2.2.1 Download the kernel source code
on:
The following works:
#!/usr/bin/python3
# Copyright (C) 2014 Noralf Tronnes
# MIT License
import io
import os
import struct
import sys
import argparse
#import urllib
#import urllib2
import urllib.request
import urllib.error
import urllib.parse
import gzip
import subprocess
import re
import json
import platform
import errno
# used by archive file and unpacked archive
DISK_USAGE_MB = 900
PROCESSOR_TYPES = range(0, 4)
PROCESSOR_TYPES_NAMES = ['BCM2835', 'BCM2836', 'BCM2837', 'BCM2711']
help = "https://github.com/RPi-Distro/rpi-source/blob/master/README.md"
script_repo = "https://github.com/RPi-Distro/rpi-source"
update_tag_file = os.path.join(os.environ.get('HOME'), '.rpi-source')
argv = sys.argv[:]
parser = argparse.ArgumentParser(description='Raspberry Pi kernel source installer',
epilog="For more help see: %s" % help)
parser.add_argument("-d", "--dest", help="Destination directory. Default is $HOME",
default=os.environ.get('HOME'))
parser.add_argument("--nomake", help="Don't run 'make modules_prepare'",
action="store_true")
if os.environ.get('REPO_URI'):
repo_uri = os.environ.get('REPO_URI')
else:
repo_uri = "https://github.com/Hexxeh/rpi-firmware"
parser.add_argument("--uri", help="Github repository to use. Default is '%s'" % repo_uri,
default=repo_uri)
parser.add_argument("--delete", help="Delete downloaded archive",
parser.add_argument("-s", "--dry-run", help="No action; perform a simulation of events that would occur but do not actually change the system.",
parser.add_argument("-v", "--verbose", help="Verbose",
parser.add_argument("-q", "--quiet", help="Quiet",
parser.add_argument("-g", "--default-config", help="Generate a default kernel configuration with 'make bcmrpi_defconfig'",
parser.add_argument("--processor", type=int, choices=PROCESSOR_TYPES, help="Override Processor type")
parser.add_argument("--skip-gcc", help=argparse.SUPPRESS, action="store_true") # Deprecated
parser.add_argument("--skip-space", help="Skip disk space check",
parser.add_argument("--skip-update", help="Skip checking for update to this script",
parser.add_argument("--tag-update", help="Tell the update mechanism that this is the latest version of the script",
parser.add_argument("--download-only", help="Just download the kernel tarball, without unpacking source and installing it",
action="store_true",)
args = parser.parse_args()
class Kernel:
pass
def debug(str):
if args.verbose:
print(str)
def info(str):
if not args.quiet:
print("\n *** %s" % str)
def warn(str):
if not args.quiet:
print("\n !!! %s" % str)
def fail(str):
sys.stderr.write("ERROR:\n%s\n\nHelp: %s\n" % (str, help))
exit(1)
def sh(cmd):
debug("%s" % cmd)
if not args.dry_run:
subprocess.check_call(cmd, shell=True)
def sh_out(cmd):
process = subprocess.Popen(cmd, shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = process.communicate()
errcode = process.returncode
if errcode:
return None
return out
def writef(f, str, mode='w'):
debug("writef(%s)" % f)
with open(f, mode) as f:
f.write(str)
def download(url):
debug("download: %s" % url)
try:
res = urllib.request.urlopen(url).read()
except urllib.error.HTTPError as e:
fail(
"Couldn't download %s, HTTPError: %s\n\n%s"
% (url, e.code, json.dumps(json.load(e), indent=4))
fail("Couldn't download %s, URLError: %s" % (url, e.args))
return res
def download_to(url, file):
debug("download_to: %s -> %s" % (url, file))
urllib.request.urlretrieve (url, file)
def update_get_head():
if update_get_head.ref:
return update_get_head.ref
repo_short = urllib.parse.urlparse(script_repo).path
repo_api = "https://api.github.com/repos%s/git/refs/heads/master" % repo_short
res = download(repo_api)
try:
j = json.loads(res)
except ValueError:
j = {}
if 'object' in j and 'sha' in j['object']:
update_get_head.ref = j['object']['sha']
else:
warn("Self update: Could not get ref of last commit")
debug("Github returned:\n%s" % res)
return None
update_get_head.ref = None
def is_update_needed():
debug("Check for update to rpi-source")
if not os.path.exists(update_tag_file):
return True
ref = update_get_head()
if not ref:
return False
with open(update_tag_file) as f:
tag_file_ref = f.read().strip()
if ref != tag_file_ref:
return True
else:
return False
def update_tag():
if not ref:
exit(1)
info("Set update tag: %s" % ref)
writef(update_tag_file, ref)
def do_update():
# MOD: replace current script; do not assume script is located at /usr/bin/rpi-source; also keep ownership and permissions
script_name = argv[0]
info("Updating rpi-source")
sh("sudo wget %s https://raw.githubusercontent.com/RPi-Distro/rpi-source/master/rpi-source -O %s" % ("-q" if args.quiet else "", script_name))
update_tag()
info("Restarting rpi-source")
argv.insert(0, sys.executable)
os.execv(sys.executable, argv)
def check_diskspace(dir):
df = sh_out("df %s" % dir).decode()
nums = re.findall(r'(?<=\s)\d+(?=\s+)', df)
if not nums or len(nums) != 3:
info("Warning: unable to check available diskspace")
if (int(nums[2]) / 1024) < DISK_USAGE_MB:
fail("Not enough diskspace (%dMB) on %s\nSkip this check with --skip-space" % (DISK_USAGE_MB, dir))
# see if gcc major.minor version matches the one used to build the running kernel
def check_gcc():
cmd = 'gcc -dumpversion'
if errcode:
debug("gcc version check failed: '%s' returned %d" %(cmd, errcode))
gcc_ver = out.strip()
with open('/proc/version', 'r') as f:
proc_version = f.read()
gcc_ver_kernel = re.search(r'gcc version (\d\.\d\.\d)', proc_version)
if not gcc_ver or not gcc_ver_kernel:
debug("gcc version check failed: could not extract version numbers")
return
a = gcc_ver.split('.')
b = gcc_ver_kernel.group(1).split('.')
if a[:2] == b[:2]:
debug("gcc version check: OK")
else:
debug("gcc version check: mismatch between installed gcc (%s) and /proc/version (%s)" % (gcc_ver[0], gcc_ver_kernel.group(1)))
def proc_config_gz():
if not os.path.exists('/proc/config.gz'):
sh("sudo modprobe configs 2> /dev/null")
return ''
with gzip.open('/proc/config.gz', 'rb') as f:
return f.read().decode('utf-8')
def processor_type_suffix():
if processor_type == 0:
return ''
elif processor_type == 1 or processor_type == 2:
return '7'
elif processor_type == 3:
return '7l'
else:
fail("Unsupported processor_type %d" % processor_type)
def rpi_update_method(uri):
kernel = Kernel()
info("rpi-update: %s" % uri)
with open("/boot/.firmware_revision") as f:
fw_rev = f.read().strip()
info("Firmware revision: %s" % fw_rev)
repo_short = urllib.parse.urlparse(uri).path
repo_api = "https://api.github.com/repos%s" % repo_short
repo_raw = "https://raw.githubusercontent.com%s" % repo_short
kernel.git_hash = download("%s/%s/git_hash" % (repo_raw, fw_rev)).strip().decode('utf-8')
kernel.symvers = "%s/%s/Module%s.symvers" % (repo_raw, fw_rev, processor_type_suffix())
if not args.default_config:
kernel.config = proc_config_gz()
return kernel
def debian_method(fn):
kernel = Kernel()
info("Using: %s" % fn)
with gzip.open(fn, 'rb') as f:
debian_changelog = f.read().decode('utf-8')
# Find first firmware entry in log (latest entries are at the top)
fw_rev = re.search(r'firmware as of ([0-9a-fA-F]+)', debian_changelog)
if not fw_rev:
fail("Could not identify latest firmware revision")
fw_rev = fw_rev.group(1)
info("Latest firmware revision: %s" % fw_rev)
repo_raw = "https://raw.githubusercontent.com/raspberrypi/firmware"
kernel.git_hash = download("%s/%s/extra/git_hash" % (repo_raw, fw_rev)).strip().decode('utf-8')
kernel.symvers = "%s/%s/extra/Module%s.symvers" % (repo_raw, fw_rev, processor_type_suffix())
return kernel
# Taken from: https://github.com/gpiozero/gpiozero/blob/master/gpiozero/pins/local.py
# Copyright (c) 2016-2019 Dave Jones <[email protected]>
# Copyright (c) 2018 Martchus <[email protected]>
def get_revision():
revision = None
try:
with io.open('/proc/device-tree/system/linux,revision', 'rb') as f:
revision = hex(struct.unpack('>L', f.read(4))[0])[2:]
except IOError as e:
if e.errno != errno.ENOENT:
raise e
with io.open('/proc/cpuinfo', 'r') as f:
for line in f:
if line.startswith('Revision'):
revision = line.split(':')[1].strip().lower()
if revision is None:
fail("Unable to find board revision (use --processor argument)")
try:
return int(revision, base=16)
except:
fail("Unrecognized revision %r (use --processor argument)" % revision)
def get_processor_type():
if args.processor is not None:
return args.processor
# The old boards don't have the detailed revision, so to keep things simple:
if platform.machine() == "armv6l":
return 0
revision = get_revision()
if not (revision & 0x800000):
fail("Unexpected revision 0x%x (use --processor argument)" % revision)
processor = (revision & 0xf000) >> 12
if processor not in PROCESSOR_TYPES:
fail("Unexpected processor %d (use --processor argument)" % processor)
return processor
def check_bc():
if not os.path.exists('/usr/bin/bc'):
fail("bc is NOT installed. Needed by 'make modules_prepare'. On Raspberry Pi OS,\nrun 'sudo apt install bc' to install it.")
processor_type = get_processor_type()
info("SoC: %s" % PROCESSOR_TYPES_NAMES[processor_type])
# FIX usage of -d DEST with relative pathnames
args.dest = os.path.abspath(args.dest)
if args.tag_update:
update_tag()
exit(0)
if not args.skip_update and is_update_needed():
do_update()
if not os.path.isdir(args.dest):
fail("Destination directory missing: %s" % args.dest)
if not args.skip_gcc:
check_gcc()
check_bc()
debianlog = "/usr/share/doc/raspberrypi-bootloader/changelog.Debian.gz"
if os.path.exists("/boot/.firmware_revision"):
kernel = rpi_update_method(args.uri)
elif os.path.exists(debianlog):
kernel = debian_method(debianlog)
else:
fail("Can't find a source for this kernel")
info("Linux source commit: %s" % kernel.git_hash)
linux_dir = os.path.join(args.dest, "linux-%s" % kernel.git_hash)
if os.path.exists(linux_dir):
info("Kernel source already installed: %s\n" % linux_dir)
exit(1)
if not args.skip_space:
check_diskspace(args.dest)
linux_tar = os.path.join(args.dest, "linux-%s.tar.gz" % kernel.git_hash)
if not os.path.exists(linux_tar):
info("Download kernel source")
sh("wget %s -O %s https://github.com/raspberrypi/linux/archive/%s.tar.gz" % (("-q" if args.quiet else ""), linux_tar, kernel.git_hash))
else:
info("Download kernel source: Already downloaded %s" % linux_tar)
if args.download_only:
info("Downloaded kernel source tarball: %s" % linux_tar)
quit()
info("Unpack kernel source")
if args.quiet:
sh("cd %s && tar -xzf %s" % (args.dest, linux_tar))
else:
sh("cd %s && tar --checkpoint=100 --checkpoint-action=dot -xzf %s" % (args.dest, linux_tar))
# This happens automatically in a git repo, but we use a tarball
info("Add '+' to kernel release string")
with open(os.path.join(linux_dir, '.scmversion'),"w") as f:
f.write("+")
linux_symlink = os.path.join(args.dest, 'linux')
info("Create symlink: %s" % linux_symlink)
sh("rm -f %s" % linux_symlink)
sh("ln -s %s %s" % (linux_dir, linux_symlink))
info("Create /lib/modules/<ver>/{build,source} symlinks")
sh("sudo rm -rf /lib/modules/$(uname -r)/build /lib/modules/$(uname -r)/source")
sh("sudo ln -sf %s /lib/modules/$(uname -r)/build" % linux_symlink)
sh("sudo ln -sf %s /lib/modules/$(uname -r)/source" % linux_symlink)
if args.default_config or not kernel.config:
info(".config (generating default)")
sh("cd %s && make bcmrpi_defconfig" % (linux_symlink,))
sh("cd %s && make bcm2709_defconfig" % (linux_symlink,))
sh("cd %s && make bcm2711_defconfig" % (linux_symlink,))
else:
else:
info(".config")
writef(os.path.join(linux_dir, '.config'), kernel.config)
info("Module.symvers")
download_to(kernel.symvers, os.path.join(linux_dir, "Module.symvers"))
sh("cd %s && cp -a Module.symvers Module.symvers.backup" % linux_dir)
if not args.nomake:
info("make modules_prepare")
sh("cd %s && make modules_prepare %s" % (linux_symlink, (" > /dev/null" if args.quiet else "")))
if not os.path.exists('/usr/include/ncurses.h'):
info("ncurses-devel is NOT installed. Needed by 'make menuconfig'. On Raspberry Pi OS,\nrun 'sudo apt install libncurses5-dev' to install it.")
if args.delete:
info("Delete downloaded archive")
sh("rm %s" % linux_tar)
info("Help: %s" % help)
