RPi HQ Camera (B0273) autofocus not working, random blurry focus
Hi, I’m having trouble with my IMX477 AF camera (B0273, the motorized-focus HQ one for Jetson). The camera itself seems to work, but the autofocus function is just not working at all. I’ve seen some forum posts saying you have to change a resistor on the PCB, but I’m honestly not sure if that’s the right way to fix it. Can someone explain why the AF function isn’t working?
Setup: B0273 IMX477 12MP HQ AF/motorized-focus camera on a Jetson. I’m planning to use it in a drone system eventually.
Hi, thanks for reaching out. Before we go down the road of hardware mods (and I’d strongly advise against randomly swapping resistors on the PCB), please check the official documentation for this camera first:
https://www.arducam.com/docs/camera-for-jetson-nano/native-jetson-cameras-imx219-imx477/imx477-12mp-auto-focus-motorized-focus-camera/
There are specific steps to get the motorized focus working on the Jetson (driver + I2C setup), and a lot of the “resistor mod” posts you’ll find online are for a completely different problem or an old revision. Go through that doc and let us know if you still have problems after that.
OK, I went through the docs. The camera works somehow now, but I have a different problem.
When I take images without touching the camera at all, the blur / focus is totally random. Same camera, same position, and each shot comes out with a different amount of blur. I’ve attached two images that were taken back-to-back without moving anything.
What is the root cause of this and how do I solve it? This is going to break things for my drone build if the focus is just random between frames. The AF thing still doesn’t seem right either.
Thanks for the images and the details, that helps. To narrow down the image/focus issue I need a few things from you:
  1. What lens is mounted on the IMX477 AF module right now?
  2. Can you confirm all the pictures you attached are from the same camera?
  3. What’s the focus distance — the distance from the camera to the object you’re shooting?
Also, please double-check the info in the link again as a reference:
Once I have those answers we can figure out what’s causing the random blur.
Answers below:
  1. Lens is an 8 mm FL M12 lens. (I have the LN002 8mm CS and LN003 6mm M12 options as well, but the 8mm M12 is what’s mounted right now.)
  2. Yes, all images are from the same camera, same position, nothing moved between shots.
  3. The focus distance is about 1.5 m from the camera to the object.
That’s why it’s confusing me — nothing changes between frames but the blur level jumps around. Still haven’t touched any resistor on the PCB, for the record.
Perfect, that’s exactly what I needed. Quick recap of where we are so we’re on the same page:
  • Earlier you had AF not working, and we pointed you to the setup doc rather than the resistor mod. The AF/motorized-focus part still isn’t confirmed working on your side.
  • Now, with the camera otherwise running, you’re getting random blur between frames taken without touching the camera — same camera, same position, 8mm M12 lens, ~1.5 m to the object.
So we have two open items and no confirmed root cause yet for either. The random focus/blur at a fixed 1.5 m distance is the key symptom to chase, but I don’t want to hand you a “fix” that isn’t verified for your setup — especially not a PCB resistor change based on random forum posts.
Next step: let me look closer at the images and the 8mm M12 lens setup, since that focal length/lens combination matters a lot for focus behavior. Can you also grab a couple more samples at the same 1.5 m distance and try to keep the same lighting? Then reply here and we’ll continue from there. If it still misbehaves after that, we’ll dig into the AF driver/motor control side.
