RPi Global Shutter Camera frontend timeout using Active Cable Extension Kit after firmware update
Hoping someone here can help — I’m having a persistent issue with the Active Cable Extension Kit for RPi Camera Modules (SKU: U6248) and the Raspberry Pi Global Shutter Camera.
After a recent firmware update, the camera no longer works through the extension kit. The issue was present before the update too, and it’s still happening on units that came back from the vendor with the new firmware applied.
Here’s what I’m seeing with libcamera:
[0:00:41.463302029] [1706] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+99-1230f78d
[0:00:41.472963196] [1711] INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:42:16)
[0:00:41.487755603] [1711] INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/imx296@1a to CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0
[0:00:41.490898085] [1706] INFO Camera camera.cpp:1197 configuring streams: (0) 640x480-XBGR8888 (1) 1456x1088-BGGR_PISP_COMP1
[0:00:41.491007418] [1711] INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx296@1a - Selected sensor format: 1456x1088-SBGGR10_1X10 - Selected CFE format: 1456x1088-PC1B
[0:00:47.562364081] [1711] WARN V4L2 v4l2_videodevice.cpp:2127 /dev/video4[20:cap]: Dequeue timer of 1000000.00us has expired!
[0:00:47.562401081] [1711] ERROR RPI pipeline_base.cpp:1366 Camera frontend has timed out!
[0:00:47.562407563] [1711] ERROR RPI pipeline_base.cpp:1367 Please check that your camera sensor connector is attached securely.
[0:00:47.562412914] [1711] ERROR RPI pipeline_base.cpp:1368 Alternatively, try another cable and/or sensor.
The camera is detected fine with rpicam-hello --list-cameras, but it can never actually connect and display an image. I’m testing on both a Raspberry Pi 4b and Pi 5, both running the latest Bookworm OS. Same result on both.
Thanks for the detailed report and logs. I can confirm we’re seeing this issue specifically with the Cable Extension Kit (U6248) when paired with the IMX296-based Global Shutter Camera.
Looking at your logs: the camera is correctly detected via I2C (imx296@1a), it registers to the CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0 — so the I2C side is working fine. The problem is that the video stream never starts, which triggers the dequeue timer expiration and the frontend timeout error.
We’re not yet sure what’s causing this. The sensor format negotiation looks normal (1456x1088-SBGGR10_1X10), so it’s something further downstream in the CSI pipeline. Investigation is ongoing — I’ll update when we have more.
Just to confirm — this is the official Raspberry Pi Global Shutter Camera (RPi SKU: SC0715), which uses the Sony IMX296LQR-C sensor. Not a third-party module.
https://core-electronics.com.au/catalog/product/view/id/54321
Appreciate the confirmation. That’s actually interesting — we’ve internally verified the U6248 Cable Extension Kit with both the official RPi IMX296 Global Shutter Camera and our own B0445 IMX296 color global shutter camera (the UCTronics one: 1.58MP IMX296 Color Global Shutter Camera Module with M12 Lens for Raspberry Pi), and both worked in our testing.
So this compatibility issue with the official RPi IMX296 module through the extension kit is unexpected. Let’s dig deeper — can you confirm whether the camera works when connected directly to the Pi without the extension kit?
Yes, I’ve tested that. The camera works perfectly when connected directly to the Pi — it’s only when going through the Active Cable Extension Kit that it fails.
Here’s my exact hardware setup:
Pi 5 setup:
  • Active Cable Extension Kit for RPi Camera Modules (SKU: U6248)
  • Raspberry Pi Global Shutter Camera (RPi SKU: SC0715)
  • Raspberry Pi 5 Model B 8GB
Pi 4 setup:
  • Raspberry Pi 4 Model B 8GB
Both tested — direct connection works on both Pi 4 and Pi 5, but the extension kit fails on both. So it’s not Pi-model specific either.
Good data point. Before we go further down the IMX296 rabbit hole, could you also test the extension kit with an IMX708 camera (Camera Module v3) if you have one available? That’ll help us figure out if this is isolated to the IMX296 sensor or if it’s a broader issue with the extension kit itself.
Just tested — the Active Cable Extension Kit works absolutely fine with the Pi Camera Module v3 (IMX708). No issues at all.
So the problem is definitely isolated to the Global Shutter Camera (IMX296) when used with the extension kit.
Thanks for running that test — that narrows things down significantly. It’s something specific to the IMX296 + extension kit combination.
I grabbed a U6248 unit from our stock and tested it here with the official RPi IMX296 Global Shutter Camera, and it worked as expected on my end. I’ve attached screenshots showing the preview working and the hardware connection: [preview.png] and [hardware_connection.jpg].
This makes me wonder — could this be a batch-specific issue with the particular U6248 kits you have? Are you seeing this on all units you’ve tried, or just some?
Before I go down the batch-variance path, can you share the exact setup instructions you’re using on your side? I want to eliminate any possibility that I’m doing something differently in the setup procedure.
Fair call. Here’s the quick start guide we’re following: Ethernet Extension Kit - Arducam Wiki
That covers the hardware connection and the software setup steps. Give that a run and let us know how you go.
Alright, I followed the guide to the letter and retested. Unfortunately, the issue is still there — and it’s repeatable on every single unit we currently have.
Here’s exactly what I did and what happened:
Hardware used:
  • Official Raspberry Pi 4 Power Supply (USB-C, 5.1V, 15.3W)
  • Raspberry Pi Global Shutter Camera (IMX296)
  • Active Cable Extension Kit for RPi Camera Modules (U6248)
Software: Pi OS Bookworm 64-bit
Setup steps:
  1. Connected the Active Cable Extension Kit hardware as per the guide
  2. Followed the IMX296 software setup from the Arducam docs
  3. Edited /boot/firmware/config.txt — changed camera_auto_detect=1 to camera_auto_detect=0
  4. Saved, rebooted
  5. Ran libcamera-still
WITH the extension kit (FAILED):
pi@raspberrypi:~ $ libcamera-still
[0:08:30.983770511] [2266] INFO Camera camera_manager.cpp:326 libcamera v0.5.0+84-79f583c3-dirty (2025-05-06T02:52:19BST)
[0:08:31.033490103] [2269] WARN RPiSdn sdn.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:08:31.035305260] [2269] INFO RPI vc4.cpp:455 Registered camera /base/soc/i2c0mux/i2c@1/imx296@1a to Unicam device /dev/media4 and ISP device /dev/media1
[0:08:31.035417757] [2269] INFO RPI pipeline_base.cpp:1160 Using configuration file ‘/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml’
Made X/EGL preview window
Mode selection for 728:544:12:P
SRGGB10_CSI2P,1456x1088/0 - Score: 1318
[0:08:31.102788491] [2266] INFO Camera camera.cpp:1205 configuring streams: (0) 728x544-YUV420 (1) 1456x1088-SBGGR10_CSI2P
[0:08:31.103318712] [2269] INFO RPI vc4.cpp:630 Sensor: /base/soc/i2c0mux/i2c@1/imx296@1a - Selected sensor format: 1456x1088-SBGGR10_1X10 - Selected unicam format: 1456x1088-pBAA
[0:08:32.695801565] [2269] WARN V4L2 v4l2_videodevice.cpp:2150 /dev/video0[13:cap]: Dequeue timer of 1000000.00us has expired!
[0:08:32.695921878] [2269] ERROR RPI pipeline_base.cpp:1420 Camera frontend has timed out!
[0:08:32.695952179] [2269] ERROR RPI pipeline_base.cpp:1421 Please check that your camera sensor connector is attached securely.
[0:08:32.695981350] [2269] ERROR RPI pipeline_base.cpp:1422 Alternatively, try another cable and/or sensor.
WITHOUT the extension kit — direct connection (WORKED):
[0:09:56.712161738] [2317] INFO Camera camera_manager.cpp:326 libcamera v0.5.0+84-79f583c3-dirty (2025-05-06T02:52:19BST)
[0:09:56.761602073] [2320] WARN RPiSdn sdn.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:09:56.763384713] [2320] INFO RPI vc4.cpp:455 Registered camera /base/soc/i2c0mux/i2c@1/imx296@1a to Unicam device /dev/media4 and ISP device /dev/media1
[0:09:56.763491411] [2320] INFO RPI pipeline_base.cpp:1160 Using configuration file ‘/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml’
[0:09:56.847061019] [2317] INFO Camera camera.cpp:1205 configuring streams: (0) 728x544-YUV420 (1) 1456x1088-SBGGR10_CSI2P
[0:09:56.847608219] [2320] INFO RPI vc4.cpp:630 Sensor: /base/soc/i2c0mux/i2c@1/imx296@1a - Selected sensor format: 1456x1088-SBGGR10_1X10 - Selected unicam format: 1456x1088-pBAA
I’ve also attached photos of my hardware setup for reference. Same timeout every time through the extension kit — and as you can see, the direct connection log shows the exact same pipeline initialization up to the stream configuration, but it actually gets frames through without the timeout.
What stands out to me: both paths negotiate the same sensor format (1456x1088-SBGGR10_1X10) and unicam format (1456x1088-pBAA), so the negotiation isn’t the problem — the CSI data just never arrives when the extension kit is in the path.
Thanks for the extremely thorough logs and the setup photos — that’s really helpful. Your analysis is spot on: the I2C communication and format negotiation are completing successfully in both cases, which means the sensor is being detected and configured correctly. The failure is specifically at the point where actual video frames should start flowing from the sensor through the CSI path.
The key difference between the IMX296 and the IMX708 (which works fine) is likely at the electrical/timing level — the IMX296 global shutter sensor may have tighter CSI signal timing requirements that the active cable extension isn’t reliably meeting. The fact that we can’t reproduce it on our test units but you’re seeing it across your entire stock suggests there might be a subtle manufacturing variance at play.
At this stage, we’re still investigating the root cause. As a workaround for now, the camera does function correctly with a direct connection. Once we have more from our engineering team on what’s going wrong in the CSI signal path with this specific sensor + extension kit combination, I’ll update this thread.
