Amazon
OV5642
ESP-32 dev board, Arduino, Python (OpenCV)
I followed the instructions on ArduCAM_ESP32S_UNO GitHub page and the info in the ArduCAM_ESP32_Capture.ino file.
5. Problems you were having?
I am trying to capture images from my OV5642 using the http://{ip address}/capture method (described in ArduCAM_ESP32_Capture.ino). I am using python to send server requests and it works fine unless there is some kind of disruption of the request - the arduino serial monitor will read
capture total_time used (in miliseconds):0
and will no longer acquire images, the serial monitor will also read capture total_time used (in miliseconds):0 for each http://{ip address}/capture request.
The Arduino serial monitor will read :
CAM Capturing
11:29:35.497 -> capture total_time used (in miliseconds):0
11:29:35.497 -> CAM Capture Done.
11:29:35.754 -> send total_time used (in miliseconds):263
11:29:35.754 -> CAM send Done.
when acquisition is working properly the cature total time used will be in the 100-500 range.
Turning on and off the camera works but isn’t useful -
How can I send a request to the camera to prevent this from happening. I guess there must be a command that I can send to reset the acquisition or have the desired effect.
Thanks!
Damian
