Request for Source Files or Alternative Solutions for Using Arducam TOF Camera with Raspberry Pi CM4 On Yocto
I am working on integrating the Arducam TOF camera with a Raspberry Pi Compute Module 4 (CM4) using my custom Linux image built with Yocto (Scratchgap). However, I am unable to find the source files for the following SDKs:
arducam-config-parser-dev
arducam-evk-sdk-dev
arducam-tof-sdk-dev
These source files are essential for creating recipes and building the SDKs to use them with my custom Yocto image.
Could you kindly provide the source files for these SDKs or guidance on where to find them? Alternatively, if the source files cannot be shared, are there any other solutions or approaches you could recommend to enable the use of the Arducam TOF camera with my Yocto-based setup?
Thank you in advance for your support!
The source for the config parser seems to be on github: GitHub - ArduCAM/arducam_config_parser
Have you checked if the instalation instructions for the evk (GET STARTED — Arducam EVK SDK (v1.0.0) documentation) and tof (Deploy the operating environment — Arducam Tof SDK (0.1.10) documentation) work under yocto?
Both seem to be using GitHub - ArduCAM/arducam_ppa which contains all the bits you need, for x86, 32-bit arm, and 64-bit arm. So long as you have any prerequisite libraries installed you will probably(?) be fine.
At this point aarch64 (aka 64-bit arm) has a high degree of portability between distros, and even SoCs for everything but device trees. So I would give it a go.
Arducam sadly doesn’t always distribute source for everything. You will have to ask them the why, but in some cases I believe they have NDAs with the vendors in question. It could be the case here.
I was worried that the SDKs would depend on many libraries with strict version constraints.
I just downloaded and extracted these packages, and actually, I can integrate them as-is into a recipe for Yocto.
Anyway, thank you for your feedback!
Of course, I am so glad that worked for you!
I understand the concern, I can say that from my experience the Arducam libraries tend not to have complicated dependency webs (thank goodness).
