Hi all. I have a Raspberry Pi 5 Model B Rev 1.0 with Bullseye 64-bit and I’m trying to get an imx477 camera working. The camera works fine on my Raspberry Pi 3 Model B Rev 1.2. I followed the usual steps to enable the imx477 camera driver via sudo raspi-config → Advanced Options, but on the Pi 5 the Advanced Options menu doesn’t show the Glamor graphic acceleration or GL Driver entries at all. Am I missing something, or are these options somewhere else now?
Just to be clear, you’re running Bullseye 64-bit on a Pi 5? Bullseye is not supported on the Raspberry Pi 5 — the Pi 5 requires Bookworm. Because of that, raspi-config won’t show the Glamor graphic acceleration / GL Driver options, and you don’t need to enable Glamor on the Pi 5 anyway. Those graphics settings were for older boards and OS versions.
Yeah, it’s Bullseye 64-bit on the Pi 5 Model B Rev 1.0. I was following an older guide that said to enable Glamor and GL Driver before enabling the camera. So those steps are obsolete on the Pi 5? If so, what’s the correct way to enable the imx477 driver?
Correct, those raspi-config graphics options are not applicable to the Pi 5. The root issue here is the unsupported OS — you should be using Bookworm 64-bit. On Bookworm, the imx477 driver is enabled directly in config.txt rather than through the Glamor/GL settings.
Okay, that makes sense. So I’ll reflash with Bookworm 64-bit. After that, how do I actually enable the imx477 driver?
Once you’re on Bookworm, run: sudo nano /boot/firmware/config.txt. Add the line dtoverlay=imx477 under the [all] section at the bottom of the file. Save, reboot the Pi, then use a libcamera command to verify the camera is detected. The official camera software docs are here: https://www.raspberrypi.com/documentation/computers/camera_software.html
Thanks. Just to confirm: the dtoverlay=imx477 line goes under [all], and I should skip the Glamor/GL Driver configuration entirely on the Pi 5?
Yes. Add dtoverlay=imx477 under [all] in /boot/firmware/config.txt, reboot, then verify with libcamera-hello or libcamera-still. The Glamor graphic acceleration and GL (Full KMS) steps are only needed on older boards/OS versions — on the Pi 5 they’re not required for the imx477 camera.
