Kickstarter / Arducam - Model number of the product(s)?
Raspberry Pi Zero and the camera from the kickstarter - What hardware/platform were you working on?
Mac - Instructions you have followed. (link/manual/etc.)
Raspberry Pi Zero USB Webcam – Tutorials of Cytron Technologies - Problems you were having?
The camera does not show up when connecting it. This works well with Raspberry Pi Zero W and the IMX477 cam that I have in my other office. - The dmesg log from your hardware?
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
sdhci-pltfm: SDHCI platform and OF driver helper
ledtrig-cpu: registered to indicate activity on CPUs
hid: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Initializing XFRM netlink socket
NET: Registered protocol family 17
registered taskstats version 1
Loading compiled-in X.509 certificates
uart-pl011 20201000.serial: cts_event_workaround enabled
20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
printk: console [ttyAMA0] enabled
bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
sdhost: log_buf @ (ptrval) (95910000)
mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
of_cfs_init
of_cfs_init: OK
uart-pl011 20201000.serial: no DMA platform data
Waiting for root device /dev/mmcblk0p2...
random: fast init done
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address 59b4
mmcblk0: mmc0:59b4 00000 7.48 GiB
mmcblk0: p1 p2
VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 188K
Kernel memory protection not selected by kernel config.
Run /sbin/init as init process
with arguments:
/sbin/init
with environment:
HOME=/
TERM=linux
modules-load=dwc2,libcomposite
systemd[1]: System time before build time, advancing clock.
NET: Registered protocol family 10
Segment Routing with IPv6
systemd[1]: systemd 247 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
systemd[1]: Detected architecture arm.
systemd[1]: Set hostname to <piwebcam>.
random: systemd: uninitialized urandom read (16 bytes read)
systemd[1]: Initializing machine ID from random generator.
systemd[1]: Installed transient /etc/machine-id file.
systemd[1]: /usr/lib/systemd/system/uvc-webcam.service:7: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
systemd[1]: /usr/lib/systemd/system/uvc-webcam.service:8: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
systemd[1]: /usr/lib/systemd/system/usb-gadget-config.service:8: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
systemd[1]: /usr/lib/systemd/system/usb-gadget-config.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
systemd[1]: Queued start job for default target Multi-User System.
systemd[1]: Created slice system-modprobe.slice.
systemd[1]: Created slice system-serial\x2dgetty.slice.
systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Reached target Paths.
systemd[1]: Reached target Remote File Systems.
systemd[1]: Reached target Slices.
systemd[1]: Reached target Swap.
systemd[1]: Reached target Timers.
systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
systemd[1]: Listening on Journal Socket (/dev/log).
systemd[1]: Listening on Journal Socket.
systemd[1]: Listening on udev Control Socket.
systemd[1]: Listening on udev Kernel Socket.
systemd[1]: Condition check resulted in Huge Pages File System being skipped.
systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
systemd[1]: Mounting Temporary Directory (/tmp)...
systemd[1]: Starting Load Kernel Module configfs...
systemd[1]: Starting Load Kernel Module fuse...
systemd[1]: Starting Journal Service...
fuse: init (API version 7.32)
systemd[1]: Starting Load Kernel Modules...
systemd[1]: Starting Remount Root and Kernel File Systems...
systemd[1]: Starting Coldplug All udev Devices...
systemd[1]: Starting Rule-based Manager for Device Events and Files...
systemd[1]: Mounted Temporary Directory (/tmp).
systemd[1]: [email protected]: Succeeded.
systemd[1]: Finished Load Kernel Module configfs.
systemd[1]: Finished Load Kernel Module fuse.
systemd[1]: Finished Remount Root and Kernel File Systems.
systemd[1]: Reached target Local File Systems (Pre).
systemd[1]: Mounting FUSE Control File System...
systemd[1]: Mounting Kernel Configuration File System...
systemd[1]: var.mount: Directory /var to mount over is not empty, mounting anyway.
systemd[1]: Mounting /var...
systemd[1]: Started Journal Service.
dwc2 20980000.usb: supply vusb_d not found, using dummy regulator
dwc2 20980000.usb: supply vusb_a not found, using dummy regulator
systemd-journald[60]: Received client request to flush runtime journal.
dwc2 20980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
dwc2 20980000.usb: DWC OTG Controller
dwc2 20980000.usb: new USB bus registered, assigned bus number 1
dwc2 20980000.usb: irq 33, io mem 0x20980000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 5.10.11 dwc2_hsotg
usb usb1: SerialNumber: 20980000.usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mc: Linux media interface: v0.10
vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[vc_sm_connected_init]: start
[vc_sm_connected_init]: installed successfully
videodev: Linux video capture interface: v2.00
bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
bcm2835-codec bcm2835-codec: Device registered as /dev/video10
bcm2835-codec bcm2835-codec: Loaded V4L2 decode
bcm2835-codec bcm2835-codec: Device registered as /dev/video11
bcm2835-codec bcm2835-codec: Loaded V4L2 encode
bcm2835-codec bcm2835-codec: Device registered as /dev/video12
bcm2835-codec bcm2835-codec: Loaded V4L2 isp
dwc2 20980000.usb: bound driver configfs-gadget
dwc2 20980000.usb: new device is high-speed
dwc2 20980000.usb: new address 4
Using pty to log on to the raspberry, checking the camera-ctl
# /usr/bin/camera-ctl
INFO: Ignored control: repeat_sequence_header
INFO: Ignored control: h264_i_frame_period
INFO: Ignored control: h264_level
INFO: Ignored control: h264_profile
INFO: Ignored control: compression_quality
INFO: Opening /dev/video0 device
ERROR: Device open failed: No such file or directory (2)
# ls /dev/v*
/dev/vc-mem /dev/vcs /dev/vcsa1 /dev/vcsu1 /dev/video12
/dev/vchiq /dev/vcs1 /dev/vcsm-cma /dev/video10
/dev/vcio /dev/vcsa /dev/vcsu /dev/video11
# uname-a
-sh: uname-a: not found
# uname -a
Linux piwebcam 5.10.11 #1 Mon Nov 8 06:25:02 UTC 2021 armv6l GNU/Linux
# cat /etc/os-release
NAME=Buildroot
VERSION=v1.90-5-g8e9f9ac
ID=buildroot
VERSION_ID=2021.02.4
PRETTY_NAME="Buildroot 2021.02.4"
Other info requested in sticky post:
# cat /proc/meminfo
MemTotal: 409012 kB
MemFree: 377912 kB
MemAvailable: 385708 kB
Buffers: 1088 kB
Cached: 14528 kB
SwapCached: 0 kB
Active: 7812 kB
Inactive: 9728 kB
Active(anon): 52 kB
Inactive(anon): 3376 kB
Active(file): 7760 kB
Inactive(file): 6352 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 1952 kB
Mapped: 7960 kB
Shmem: 1504 kB
KReclaimable: 1404 kB
Slab: 6920 kB
SReclaimable: 1404 kB
SUnreclaim: 5516 kB
KernelStack: 328 kB
PageTables: 164 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 204504 kB
Committed_AS: 5856 kB
VmallocTotal: 614400 kB
VmallocUsed: 3160 kB
VmallocChunk: 0 kB
Percpu: 64 kB
CmaTotal: 65536 kB
CmaFree: 64176 kB
# cat /boot/config.txt
# Please note that this is only a sample, we recommend you to change it to fit
# your needs.
# You should override this file using a post-build script.
# See http://buildroot.org/manual.html#rootfs-custom
# and http://elinux.org/RPiconfig for a description of config.txt syntax
# We always use the same names, the real used variant is selected by
# BR2_PACKAGE_RPI_FIRMWARE_{DEFAULT,X,CD} choice
start_file=start.elf
fixup_file=fixup.dat
kernel=zImage
# To use an external initramfs file
#initramfs rootfs.cpio.gz
# Disable overscan assuming the display supports displaying the full resolution
# If the text shown on the screen disappears off the edge, comment this out
disable_overscan=1
# How much memory in MB to assign to the GPU on Pi models having
# 256, 512 or 1024 MB total memory
gpu_mem_256=100
gpu_mem_512=100
gpu_mem_1024=100
dtoverlay=dwc2
enable_uart=1
boot_delay=0
initial_turbo=10
- What help do you need?
Could you please point me in the right direction to make the webcam work?
