Raspberry Pi + USB3.0 Shield Plus + 2x OV2311s, hardware triggered and timestamped
Would it be possible to get hardware timestamped and synced images from 2 cameras with the below setup.
A USB3.0 Plus shield with an OV2311, via USB to a Raspberry Pi.
Said Raspberry Pi has an OV2311 connected to its camera interface.
Then the digital outputs of the Rasp Pi is wired to the two cameras for hardware triggering.
RaspCam
(*For the Raspberry Pi, the DVP 15/22 ribbon needs to be used instead I think)
With this setup I believe that the Hardware trigger will keep the images synced and the Timestamp from the USB3.0 Shield could be used for both images.
If I’m using hardware triggering is there a need for the Timestamping from the USB3.0 Shield?
The latest version of USB3.0 S has timestamp function (there is a certain error), please refer to: https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield/blob/df40b14d688062a0d2c7b5cdc7fbbffd711f0660/RaspberryPi/Cpp/Streaming_demo/Arducam_SDK/ArduCamLib.h#L105
