Raspberry Pi 5 unstable power, no display after connecting Arducam IMX219 camera HAT
Hi everyone, I’m stuck with a Raspberry Pi 5 + Arducam quad camera HAT setup and hope someone can point me in the right direction.
I have a Raspberry Pi 5 from the CanaKit Raspberry Pi 5 Starter Kit PRO, and I’m connecting an Arducam 1MP 4 Quadrascopic Camera Bundle Kit (IMX219) HAT board. As soon as I connect the HAT, power becomes unstable and the Pi 5 stops working. The only sign of life is a red LED staying on, and nothing appears on screen. I even removed the SD card to check whether it would boot at all, but it’s still just the red light and a blank screen.
Has anyone seen this before?
Thanks for the detailed report. I don’t have access to that specific CanaKit starter kit on my end, so I can’t replicate your exact setup to investigate — the configuration itself has worked in the past, but without the same kit I can’t reproduce the failure. I don’t have a concrete fix for the power/boot symptom yet, sorry about the limited help on that part.
Let me pull together the setup notes for this HAT and see if anything jumps out.
Appreciate it. Even if you can’t reproduce it, any setup notes would help — I’d like to at least rule out a config or cabling mistake on my side.
Okay, here’s what I have for the IMX219 quad HAT.
First, in your config.txt (on Bookworm it’s /boot/firmware/config.txt), delete the existing camera entry and add:
dtoverlay=imx219
Make sure you’re following the right guide — use this one:
https://docs.arducam.com/Raspberry-Pi-Camera/Multi-Camera-CamArray/quick-start/#imx219-multi-camera-kit
…not the older Quick-Start-Guide-for-Multi-Adapter-Board page.
For camera software, the reference is here:
https://www.raspberrypi.com/documentation/computers/camera_software.html#rpicam-apps
(Note: in current docs, ‘rpicam’ can be replaced with ‘libcamera’ for the older naming.)
A couple of command notes: the command libcamera-still -t 0 --camera 4 is invalid for the imx219 quad hat kit, because it requires the multiplexer. To preview camera 4 separately, check the ‘switch composition mode’ section of that guide. If you want a Python demo, take a look at RPiCamGUI on GitHub.
And the big one: by default this HAT combines all four cameras into a single 2x2 frame — it does not stream four separate frames. You can’t split that 2x2 frame into four separate frames unless you use the i2c command to set single-channel mode, and in single-channel mode the other three cameras are disabled.
Also, check the package for a 30cm 22-22 pin cable (the white one) — that’s the one you should use to connect to the Raspberry Pi 5.
Thanks, that’s really helpful. I also found I need more distance between the HAT and the camera, so I bought a longer cable. With the new longer cable, the red LED on the HAT no longer lights up and the system can’t detect the camera at all (the original cable at least powers it up).
Would the Arducam 200mm sensor extension cable for Raspberry Pi V2/V3 work here? https://www.arducam.com/product/200mm-sensor-extension-cable-for-raspberry-pi-v2-v3-support-working-on-raspberry-pi-and-jetson-nano/
I’d stop using that longer cable immediately. The cable you bought is a straight-through cable, but the one that ships with the HAT kit is not wired the same way. A straight-through cable can cause a short circuit on the HAT board — that’s why the red LED goes out and the camera stops being detected, and it can also prevent the Raspberry Pi from booting properly.
Replace it with the correct Arducam 30cm 22-pin ribbon cable designed for this HAT kit:
The cable pinout/wiring type is critical here. Using the correct cable prevents damage to the HAT board and lets the Pi boot and operate as intended.
Understood, thanks for the warning. Is there any version longer than 50cm for the HAT-to-camera connection? I really need more than 50cm of reach.
No, unfortunately there isn’t. Arducam doesn’t offer a cable longer than 50cm for this HAT-to-camera connection — 50cm is the maximum available length, so that’s the longest option you can use with this kit.
