Hi, I’m stuck trying to enable the multi-camera board and I can’t get past an error. This is for a senior project and I need to join a Zoom meeting as fast as possible, so I’d really like to get this working today.
My setup: Raspberry Pi 3B+ connected to the ArduCAM Multi-Camera Adapter board (V2.2). I’ve been entering the commands in the terminal to enable the board, but it still won’t enable and I keep getting an error.
Can anyone help me over Zoom/WhatsApp? Whatever is fastest.
Hi, happy to help. Let’s start with what’s on the screen. Can you paste the exact commands you typed and the exact error output? Also, what does ls show in your current directory?
Ok so I wrote the commands in the terminal to enable the multi camera board, and this is what happened:
cd: RaspberryPi/Multi_Camera_Adapter/Multi_Camera_Adapter_V2.2/
bash: cd: RaspberryPi/Multi_Camera_Adapter/Multi_Camera_Adapter_V2.2/: No such file or directory
So I can’t reach the folder and the board never gets enabled. I attached a screenshot of the error.
Thanks, that error usually just means the path doesn’t match the folder layout on disk. Two things to check:
Run pwd so we know where you are.
Run ls -R RaspberryPi/Multi_Camera_Adapter/ and post the output.
Also, I’ve sent you the remote support details in a private message (that includes the TeamViewer info I’d need and a scheduling link) in case we want to do this live instead. Please download TeamViewer beforehand and have the ID and password ready if we go that route.
$ pwd
/home/pi
$ ls RaspberryPi/Multi_Camera_Adapter/
Multi_Adapter_Board_4Channel
So there’s no Multi_Camera_Adapter_V2.2/ folder directly under Multi_Camera_Adapter/. That’s why the cd fails I guess. What should I cd into instead?
Also I tried to book a slot on the calendly link but I couldn’t line up a time. It’s currently 10:44 am here (Jerusalem, Israel) — could we do a meeting tomorrow at 3:00 pm? Or if it’s easier, message me on WhatsApp/Zoom so we can fix this quickly.
That output is the key. The demo was updated a while back, so the folder structure changed and the old path you’re using no longer exists. Some older tutorials still reference Multi_Camera_Adapter_V2.2/ directly, which is why the cd fails.
Ah, that makes sense. I think I was following the old path from the docs. I’ll pull the updated demo and try cd RaspberryPi/Multi_Camera_Adapter/Multi_Camera_Adapter_V2.2/python.
I couldn’t get a live session on the calendly link either, so I’m going to try this on my own first — will report back.
Update: I downloaded the latest demo and used the path with the /python suffix and the cd error is gone. I can get into the directory now. I still need to run the enable step for the board — should I just follow the README in that Multi_Camera_Adapter_V2.2_python folder?
Yes, follow the README in the updated Multi_Camera_Adapter_V2.2_python folder. Since the demo was modified, the folder layout and script names are different from the older version, so don’t reuse the old commands you had before — use the ones in the new repo only.
Run the demo and send me the output. If anything errors out, post the exact terminal text and I’ll take a look.
Still working on it — I’ll post the terminal output as soon as I run the demo. If it doesn’t work I’d still like to do a remote session. I’ve got TeamViewer ready, and the remote support details you sent privately are saved. Let me know when you can fit a session given my time zone (Jerusalem), maybe tomorrow at 3:00 pm.
The No such file or directory error was caused by an incorrect path. The path RaspberryPi/Multi_Camera_Adapter/Multi_Camera_Adapter_V2.2/ no longer exists because the demo repository was updated and the folder structure changed.
The correct path now includes an extra /python subfolder: cd RaspberryPi/Multi_Camera_Adapter/Multi_Camera_Adapter_V2.2/python — that resolves the cd error.
Run the updated demo and report back with the terminal output.
If a live session is still easier, I’ve sent the remote support details privately and you can also schedule a time here: Calendly - Arducam — just have TeamViewer installed and share the ID/password when we start. Post your results here whenever you’re ready and we’ll continue from there.
