Quick install guidelines at Arducam website outdated
    Funduino
    18MP AR1820HS (Arducam Pivariety)
    RPi
    Quick Start Guide - Arducam Wiki
  5. Problems you were having?
    The link to the Github repository is outdated.
    install_pivariety_pkgs.sh does not exist and even the tree is different than in the link you provided. ==> installing the drivers does not work.
    Using the install_driver.sh arducam_camera_selector.sh scripts instead results in file not found errors.
    Any support appreciated.
Hi there,
Could you post the output of the commands below?
uname -a
dpkg -l | grep libcamera
Thanks Dion,
before your response I started from scratch with a new install (Raspi OS Trixie [Dec 4, 2025], 32Byte, Light). Installation of the libraries now went smoothly. However, now
 rpicam-still --list-cameras
results in
No cameras available!
For completeness, I add the response to the commands you provided:
uname -a
Linux PiTrixieLight 6.12.47+rpt-rpi-v7 #1 SMP Raspbian 1:6.12.47-1+rpt1 (2025-09-16) armv7l GNU/Linux
ii  libcamera-dev                        0.6.0+rpt20251203-2                     armhf        complex camera support library (development files)
ii  libcamera-ipa:armhf                  0.6.0+rpt20251203-2                     armhf        complex camera support library (IPA modules)
ii  libcamera0.6:armhf                   0.6.0+rpt20251203-2                     armhf        complex camera support library
ii  python3-libcamera                    0.6.0+rpt20251202-1                     armhf        complex camera support library (Python bindings)
ii  rpicam-apps                          1.10.1-2                                all          Camera based applications for Raspberry Pi using the libcamera framework
ii  rpicam-apps-core                     1.10.1-2                                armhf        Camera based applications for Raspberry Pi using the libcamera framework
Thanks for any supportive response!
May be relevant as well:
dmesg | grep -E "imx477|imx219|arducam"
[    0.028968] /soc/csi@7e801000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_pivariety@c
[    0.029073] /soc/i2c0mux/i2c@1/arducam_pivariety@c: Fixed dependency cycle(s) with /soc/csi@7e801000
[    0.030498] /soc/csi@7e801000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_pivariety@c
[    0.031884] /soc/i2c0mux/i2c@1/arducam_pivariety@c: Fixed dependency cycle(s) with /soc/csi@7e801000
[    2.869318] /soc/csi@7e801000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_pivariety@c
[    2.873702] /soc/i2c0mux/i2c@1/arducam_pivariety@c: Fixed dependency cycle(s) with /soc/csi@7e801000
Hi @KaBu
Thanks for the update.
Could you please send us pictures of the hardware connection? Besides, it’d be appreciated if you post the output of the command cat /boot/firmware/config.txt here?
Unfortunately, I can’t upload the photos. The websites complains: ‘Sorry, new users can only put one embedded media item in a post.’
Anyways. The hardware setup is minimal. Imagine a bare Pi3 board, with just the flatbandcable in the camera slot (between HDMI and headphone sockets), the power supply connected and a wifi stick for SSH connection. That’s it. Nothing else.
As far as I can see, ‘config.txt’ has been modified according to the quick start instructions at your website.
# http://rptl.io/configtxt
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=0
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
dtoverlay=arducam-pivariety
# enable_uart=1
(Without these modifications, the conventional Pi-Cam worked fine.)
Dear Dion,
From extensive internet research I understood that the hardware of the U-721 adapter isn’t compatible with the Pi interface. (i2cdetect doesn’t provide an address - the Pi and the adapter aren’t able to talk to each other.) Nothing to do about that. Please, correct me if I am wrong (I have been struggeling for days and hours as well without success).
If I am correct, some clear communication from the Arducam team would be helpful and save us users from a lot of frustration. The questions I got so far didn’t touch the adapter version at all.
Hi @KaBu
We understand your frustration, and we’re sorry for any inconvenience.
You mentioned that your camera board is labelled with UC-721, which has been discontinued for a long time.
To help us confirm it, could you please send us the link to the camera module you purchased?
Thanks Dion,
I bought the module at Microelectronics and 3D printing specialist dealer | Funduinoshop
Responding to my reply, funduino removed the module from their website yesterday. So you won’t find it any more.
Regards,
Karsten
