Uctronics -
UC-512 Rev. C + 4x UC-788 Rev. B -
Linux raspberrypi 5.4.79-v7l+
RPI 4 -
V4L2 OBISP Driver for the Latest RPi OS Updates (Kernel 5.4.79 and later) - Arducam -
v4l2-ctl doens show real fps
libcamera doesn’t detect camera -
[ 31.833207] arducam_vddl: disabling
[ 31.833226] arducam_vdig: disabling
[ 31.833279] arducam_vana: disabling -
Aarducam Qtcam app shows true FPS as well as VLC
I can see preview in VLC and I could run my own python script to read the frames -
Why v4l2-ctl --list-format-ext doesn’t provide correct info (interval and FPS)?
Why camera is not detected by libcamera?
How to select mode (Y8 vs Y10)
Is the support team busy?
Sorry, obisp can only use arducamstill. you can’t use libcamera.
Sorry again, because many times I have some other things going on that cause me to forget to reply to some users. If I forget to reply please remind me again.
Thank you Edward.
How about the wrong FPS that I am getting (Interval: Discrete 0.000s (4294967294.000 fps)
How I can select between GREY, Y10P, Y10? In the list of controls, sensor mode is not available.
I think the link below will be a little helpful for you.
https://www.arducam.com/docs/cameras-for-raspberry-pi/multi-camera-adapter-board/1mp-stereo-camera-global-shutter-mipi-arducam/#16-1check-whether-the-camera-is-detected
Thank you Dion.
Do you mean “Interval: Discrete 0.000s (4294967294.000 fps)” is not an error?
