Hello everybody,
can you recommend a camera for Raspberry Pi 4 with following specs:
- IR vision (850+/-50nm)
- global shutter
- switchable between
- High-Resolution at low fps (like 1280 x 800 @ 30Hz)
- Low-Resolution at high fps (like 640 x 400 @ 220 Hz)
I would like to be able to set the horizontal & vertical offset in the high-resolution mode so that the pupil is centered for recording in the low resolution mode at high fps.
Best Regards,
Chris
