UCTRONICS
https://www.uctronics.com/arducam-4k-8mp-imx219-autofocus-usb-camera-module-without-microphone.html
Jetson Nano B01
Online documentation
Yes
I am trying to connect two Arducam B0292 usb cameras to a Jetson Nano B01. Both cameras are visible in the system as “/dev/videoX”.
When I individually run the camera view, either from the console or python script with opencv - everything works fine.
The problem arises when I try to open video from two cameras simultaneously. When I try to open video from each camera in a separate console using v4l2, the video from the first camera freezes when I open the video stream from the second camera.
I received information on the Nvidia forum to use DeepStream for this.
Using deepstream I was able to open the video from two arducam cameras in two separate consoles (for 640x480 resolution only).
However, when I tried to run a preview of the arducam cameras from a python script using deepstream, it failed again. For two Creative webcams, the same code worked fine.
The problem that repeats in the logs:
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Is it possible to run two(or more) Arducam UVC cameras on Jetson Nano B01? If yes, how? How to control it from python script?
