When I start filming with the OVM6211-RADA camera using my RPI I get the following:
pi@raspberrypi:~/MIPI_Camera/RPI $ ./arducamstill -t 0 -m 1 -awb 1 -ae 1
Open camera...
Hardware platform: c03111
Found sensor ov7251 at address 60
mode: 0, width: 640, height: 480, pixelformat: Y10P, desc: (null)
mode: 1, width: 640, height: 480, pixelformat: Y10P, desc: (null)
mode: 2, width: 640, height: 480, pixelformat: GREY, desc: (null)
mode: 3, width: 640, height: 240, pixelformat: GREY, desc: (null)
mode: 4, width: 640, height: 120, pixelformat: GREY, desc: (null)
mode: 5, width: 320, height: 240, pixelformat: GREY, desc: (null)
index: 0, CID: 0x00980914, desc: V4L2_CID_HFLIP, min: 0, max: 1, default: 0, current: 0
index: 1, CID: 0x00980915, desc: V4L2_CID_VFLIP, min: 0, max: 1, default: 0, current: 0
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 512, current: 32
index: 3, CID: 0x00980913, desc: V4L2_CID_GAIN, min: 0, max: 255, default: 16, current: 16
index: 4, CID: 0x00981901, desc: V4L2_CID_ARDUCAM_EXT_TRI, min: 0, max: 1, default: 0, current: 0
Failed to set focus, the camera may not support this control.
Start preview...
Current mode: 1, width: 640, height: 480, pixelformat: Y10P, desc: (null)
Mono camera does not support automatic white balance.
This text will be hidden
The camera does film, and the video is visible on a connected monitor. However, I want to know how to get the camera running without any error’s. I tried solving it using existing forums, but I just can’t seem to fix it.
I found a similar error on the following link:
However, I tried multiple RPI’s and camera’s so I don’t think something is broken (they also never fell or anything like that).
I followed the instructions on this link: Redirecting... to get the camera to work and film.
Is there anything you can do to help?
Thanks in advance!!!
