I try to install the Pivariety low light camera on a brand new rpi4 8Go and bullseye os but it is not working.
I’ve followed the procedure from your website:
The camera seems to be recognized:
pi@raspberrypi:~ $ dmesg | grep arducam
[ 9.718471] arducam: loading out-of-tree module taints kernel.
[ 9.733008] arducam-pivariety 10-000c: firmware version: 0x10002
[ 31.836985] arducam_vddl: disabling
[ 31.836999] arducam_vdig: disabling
[ 31.837010] arducam_vana: disabling
The following command gave me more video inputs than on your doc:
pi@raspberrypi:~ $ ls /dev/video* -l
crw-rw----+ 1 root video 81, 8 Jan 3 21:43 /dev/video0
crw-rw----+ 1 root video 81, 9 Jan 3 21:43 /dev/video1
crw-rw----+ 1 root video 81, 4 Jan 3 21:43 /dev/video10
crw-rw----+ 1 root video 81, 5 Jan 3 21:43 /dev/video11
crw-rw----+ 1 root video 81, 6 Jan 3 21:43 /dev/video12
crw-rw----+ 1 root video 81, 0 Jan 3 21:43 /dev/video13
crw-rw----+ 1 root video 81, 1 Jan 3 21:43 /dev/video14
crw-rw----+ 1 root video 81, 2 Jan 3 21:43 /dev/video15
crw-rw----+ 1 root video 81, 3 Jan 3 21:43 /dev/video16
crw-rw----+ 1 root video 81, 7 Jan 3 21:43 /dev/video18
On the opposite, the next command returned less options than on your site!!!
pi@raspberrypi:~ $ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'pRAA' (10-bit Bayer RGRG/GBGB Packed)
Size: Discrete 1920x1080
[1]: 'RG10' (10-bit Bayer RGRG/GBGB)
After a reboot libcamera crash.
Please note that as libcamera is installed by default on bullseyes, i havent installed it.
pi@raspberrypi:~ $ libcamera-still -t 5000 -o test.jpg
[0:32:48.849164122] [2510] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3156-f4070274
[0:32:48.865103188] [2512] WARN CameraSensor camera_sensor.cpp:197 'arducam-pivariety 10-000c': Recommended V4L2 control 0x009a0922 not supported
[0:32:48.879351067] [2512] WARN CameraSensor camera_sensor.cpp:249 'arducam-pivariety 10-000c': The sensor kernel driver needs to be fixed
[0:32:48.879523103] [2512] WARN CameraSensor camera_sensor.cpp:251 'arducam-pivariety 10-000c': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:32:48.880650388] [2512] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'arducam-pivariety'
[0:32:48.880823942] [2512] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:32:48.880894478] [2512] WARN CameraSensor camera_sensor.cpp:414 'arducam-pivariety 10-000c': Failed to retrieve the camera location
[0:32:48.890372497] [2512] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
[0:32:48.890523347] [2512] ERROR IPARPI raspberrypi.cpp:187 Could not create camera helper for arducam-pivariety
[0:32:48.890593680] [2512] ERROR RPI raspberrypi.cpp:1009 Failed to load a suitable IPA library
Thanks for the help.
