@Edward
GitHub - ArduCAM/Arducam-Pivariety-V4L2-Driver: This driver is used for Arducam mipi camera with Pivariety board releases has no changelog, so we cannot know what’s is going on.
Even if Arducam prefers put binaries on the same release rather than do one release per release on github, you can also add a VERSION file or so with the changes made.
Thanks
Edward
February 15, 2023, 2:15am
2
hi @AnotherDredd
We have taken your suggestion.
We’ll put an update note on the docs site, and I’ll send you a link when this is done.
Thank you for your support all the time.
Edward
February 21, 2023, 5:11am
4
@AnotherDredd @hikinghack
For now we will put the update in my link below.
https://docs.arducam.com/#whats-new
The content inside is not perfect yet, I will continue to update.
Thanks a lot @Edward
I’ve observed there is a change in controls min/max values, could you confirm?
Autofocus were 0…1000 and now is 0…32 ?
libcamera-still -v 2
Available controls:
ScalerCrop : [(0, 0)/128x128..(0, 0)/9248x6944]
Sharpness : [0.000000..16.000000]
Contrast : [0.000000..32.000000]
NoiseReductionMode : [0..4]
FrameDurationLimits : [99997..237626997]
LensPosition : [0.000000..32.000000]
ColourCorrectionMatrix : [-16.000000..16.000000]
AfTrigger : [0..1]
AwbMode : [0..7]
AfMode : [0..2]
AeEnable : [false..true]
Saturation : [0.000000..32.000000]
Brightness : [-1.000000..1.000000]
AfSpeed : [0..1]
AeMeteringMode : [0..3]
AwbEnable : [false..true]
AfWindows : [(0, 0)/0x0..(65535, 65535)/65535x65535]
AfPause : [0..2]
AeConstraintMode : [0..3]
AfRange : [0..2]
ExposureTime : [254..237626884]
ColourGains : [0.000000..32.000000]
ExposureValue : [-8.000000..8.000000]
AnalogueGain : [1.000000..10.080000]
AfMetering : [0..1]
AeExposureMode : [0..3]
Edward
February 21, 2023, 8:29am
6
@AnotherDredd
I have submitted the update of this part to the colleague who updated the website, and he may not have uploaded it yet.
But this [0,32] range is a maximum value that libcamara hardcodes to adapt to all cameras.
For the specific range, you can refer to
cat /usr/share/libcamera/ipa/raspberrypi/arducam_64mp.json
You can see that there is a “map” at the end: [0.0, 0 ,15.0,1023], which can be understood as 0,15 corresponds to 0,1023
