Please Help, Multi camera adapter v2.2 with 2 ov5647 camera doesnt work
i have been handle this for week, i cant handle this anymore… i dont know what to do plz help
i wanna handle opencv but i cant do that because of this
Os: legacy(buster)
config.txt
Raspberry Pi Documentation - Configuration
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
dtparam=i2c_vc=on
dtparam=audio=on
[pi4]
Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
#dtoverlay=vc4-fkms-v3d
gpu_mem=256
enable_uart=1
dtoverlay=w1-gpio
start_x=1
#dtoverlay=ov5647
dtoverlay=camera-mux-4port,cam0-ov5647,cam3-ov5647
i connected on A and D port, then ‘libcamera-hello list’ shows two cameras connected.
pi@raspberrypi:~ $ cd libcamera-install/libcamera-apps/build
pi@raspberrypi:~/libcamera-install/libcamera-apps/build $ ./libcamera-hello --list
Available cameras
0 : ov5647 [2592x1944] (/base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36)
Modes: ‘SGBRG10_CSI2P’ : 640x480 [58.92 fps - (16, 0)/2560x1920 crop]
1296x972 [43.25 fps - (0, 0)/2592x1944 crop]
1920x1080 [30.62 fps - (348, 434)/1928x1080 crop]
2592x1944 [15.63 fps - (0, 0)/2592x1944 crop]
1 : ov5647 [2592x1944] (/base/soc/i2c0mux/i2c@1/pca@70/i2c@3/ov5647@36)
pi@raspberrypi:~ $ sudo dmesg | grep ov5647
[ 7.771320] platform video-mux: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36
[ 7.952379] platform video-mux: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/pca@70/i2c@3/ov5647@36
[ 8.330975] ov5647 23-0036: Consider updating driver ov5647 to match on endpoints
[ 8.350186] ov5647 26-0036: Consider updating driver ov5647 to match on endpoints
pi@raspberrypi:~/libcamera-install/libcamera-apps/build $ vcgencmd get_camera
supported=1 detected=0, libcamera interfaces=1
pi@raspberrypi:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_python $ sudo chmod +x init_camera.sh
pi@raspberrypi:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_python $ sudo ./init_camera.sh
----Test i2c1
00: – – – – – – – – – 0c – – –
30: – – – – – – 36 – – – – – – – – –
70: 70 – – – – – – –
----Detecting the /dev/video0 device
video0 detected!
—Start testing each camera
if all of them are normal, after it finished,you will see four image in the current path.
Start testing the camera A
sh: 1: libcamera-still: not found
Start testing the camera B
Start testing the camera C
Start testing the camera D
pi@raspberrypi:~/libcamera-install/libcamera-apps/build $ ./libcamera-still
Made X/EGL preview window
[0:00:45.534355972] [1046] INFO Camera camera_manager.cpp:298 libcamera v0.0.5+22-76e1cb9f
[0:00:45.887121305] [1047] INFO RPI vc4.cpp:390 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 to Unicam device /dev/media4 and ISP device /dev/media2
[0:00:46.032385342] [1047] INFO RPI vc4.cpp:390 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@3/ov5647@36 to Unicam device /dev/media4 and ISP device /dev/media2
[0:00:46.036319472] [1046] INFO Camera camera.cpp:1028 configuring streams: (0) 1296x972-YUV420
[0:00:46.038132027] [1047] INFO RPI vc4.cpp:512 Sensor: /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
[0:00:47.142002989] [1047] WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[16:cap]: Dequeue timer of 1000000.00us has expired!
[0:00:47.142138860] [1047] ERROR RPI pipeline_base.cpp:1321 Camera frontend has timed out!
[0:00:47.142192804] [1047] ERROR RPI pipeline_base.cpp:1322 Please check that your camera sensor connector is attached securely.
[0:00:47.142246101] [1047] ERROR RPI pipeline_base.cpp:1323 Alternatively, try another cable and/or sensor.
i did everything i found to do this… but i think that there’s no other way plz help me
i think that i properly connected cameras and adapter but i uploaded pics just in case
