OV2640 2MP -
Raspberry pi pico. -
I am using the https://github.com/ArduCAM/RPI-Pico-Cam/tree/master/tflmicro/Arducam/src repository which has a function to set the camera as RGB565. -
I am trying to get the RGB565 data from the camera but the code stops when it tries to read the data from spi for RGB_565. The camera seems to work when using YUV. -
I’ve tried using the print function to see where the code stops and it seems to stop at spi_read_blocking(SPI_PORT, BURST_FIFO_READ, value, length); -
I am trying to read the rgb data from the camera using the tflmicro library from the RPI-Pico-Cam repository however, it doesn’t seem to work. The code I am currently using is similar to the code for Arducam_demo
#include <stdio.h>
#include <string.h>
#include “pico/stdlib.h”
#include “hardware/i2c.h”
#include “hardware/spi.h”
#include “pico/binary_info.h”
#include “src/arducam.h”
int main() {
uint8_t table[320*240] = {};
picoSystemInit();
if(spiBusDetect()){
return 1;
if(ov2640Probe()){
return 1;
ov2640Init(RGB565);
arducam.setJpegSize(res_320x240); // I have tried both deleting and keeping this here but it doesn’t seem to work
while (true) {
capture(&table);
return 0;
The code goes up to capture and then stops, inside the function it seems to stop at
