From you
t
64mp arducam
RPi
manual and then troubleshooting the forum
Being able to use Picamera2 in Crontab
calling libcamera-still from a call to the command line
Hi! I got our 64mp arducam working with a RPI 4, and I can write python code and use picamera2 and take photos and set focus and stuff and that’s working ok when I run the python file from the command line or Thonny or Geany.
but when I try to have the same script run from Crontab it won’t start. When i look at the output it will say something like “cannot find camera”
I ended up doing a workaround where instead of calling picamera2, i ended up doing calls to the cmd line from Python, but found I had to write the call like:
cmd = "/usr/local/bin/libcamera-still -o "+filename
Instead of normally just writing:
cmd = "libcamera-still -o "+filename
I guess crontab uses a different path or something to get to the things like libcamera still, and i got this path from running the command line:
[email protected]:~ $ which libcamera-still
is there something i need to do in my python code like with the imports?
