uctronics
2. Model number of the product(s).
Arducam IMX219 Auto Focus IR Sensitive (NoIR) Camera Module, drop-in replacement for Raspberry Pi V2 and Jetson Nano Camera
over
Arducam Raspberry Pi Noir Camera Module, 8MP IMX219 RPi-CAM-V2
Raspberry pi 4, 2GB
Installed all required drivers and Picamera2. All preview and recordings are working.
5. Problems you were having.
when using the below code, the first two frames captured are real, the pixels of the other 4 has constant value of 127 or 128.
- What help do you need?
how to capture relevant images
code:
import time
from pprint import *
from picamera2.encoders import Encoder
import sys
import matplotlib.pyplot as plt
import json
import libcamera
import numpy as np
import scipy.iodef capture(ET,AG):
with open(“conf.json”, “r”) as read_content:
conf = json.load(read_content)conf["controls"]["NoiseReductionMode"] = libcamera.controls.draft.NoiseReductionModeEnum.Off conf['controls']['ExposureTime'] = ET conf['controls']['AnalogueGain'] = AG picam2 = Picamera2() still_config = picam2.create_still_configuration(**conf) picam2.align_configuration(still_config) size = still_config['main']['size'] buffer_count = conf['buffer_count'] prog_buffer = np.zeros((buffer_count, size[1],size[0],3)) picam2.configure(still_config) picam2.still_configuration #picam2.sensor_resolution picam2.start() for ii in range(buffer_count): print(ii) prog_buffer[ii,:,:,:] = picam2.capture_array() return picam2, prog_buffer
scipy.io.savemat(‘./record/arrdata_ET-{0}_AG-{1}.mat’.format(ET,AG), mdict={‘data’: prog_buffer})
for ET in [4000]:
for AG in [10]:
picam2, buffer = capture(ET,AG)
Blockquote
