Pi4 Hawkeye 64MP - no preview window when doing a rpicam-hello test
  1. Model number of the product(s)?
Hawkeye 64MP B0399
  1. What hardware/platform were you working on?
headless Raspberry Pi 4B running bookworm, I SSH into it from a windows laptop
  1. Instructions you have followed. (link/manual/etc.)
Quick Start Guide from Arducam wiki. I have not installed the focus software onto my pi (for the Hawkeye focus features) and I have a arducam pan/tilt kit that I have not yet hooked up as I’m working on the installation one step at a time.
  1. Problems you were having?
I think the camera is installed correctly - rpicam-still with the JPEG option results in a good jpeg file.
when I run rpicam-hello, I get no popup video window and here is the stuff that shows up in my SSH terminal window:
$ rpicam-hello
[0:50:38.553519469] [1979] INFO Camera camera_manager.cpp:326 libcamera v0.5.1+127-81ec2a3b-dirty (2025-07-23T03:47:08BST)
[0:50:38.610752625] [1982] WARN RPiSdn sdn.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:50:38.613567607] [1982] INFO RPI vc4.cpp:448 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media2
[0:50:38.613740847] [1982] INFO RPI pipeline_base.cpp:1146 Using configuration file ‘/usr/share/libcamera/pipeline/rpi/vc4/arducam_64mp.yaml’
Made X/EGL preview window
Made DRM preview window
Preview window unavailable
Mode selection for 4624:3472:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 13359.2
SRGGB10_CSI2P,1920x1080/0 - Score: 11359.2
SRGGB10_CSI2P,2312x1736/0 - Score: 9096
SRGGB10_CSI2P,3840x2160/0 - Score: 5359.24
SRGGB10_CSI2P,4624x3472/0 - Score: 1000
SRGGB10_CSI2P,8000x6000/0 - Score: 2476.58
SRGGB10_CSI2P,9152x6944/0 - Score: 3041.47
Stream configuration adjusted
[0:50:38.655017030] [1979] INFO Camera camera.cpp:1205 configuring streams: (0) 4624x3472-YUV420/sYCC (1) 4624x3472-SRGGB10_CSI2P/RAW
[0:50:38.655438342] [1982] INFO RPI vc4.cpp:623 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
#7 (0.00 fps) exp 94813.00 ag 5.99 dg 1.00
#8 (10.00 fps) exp 94699.00 ag 5.99 dg 1.00
#9 (10.00 fps) exp 94813.00 ag 5.99 dg 1.00
#10 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#11 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#12 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#13 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#14 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#15 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#16 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#17 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#18 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#19 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#20 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#21 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#22 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#23 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#24 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#25 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#26 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#27 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#28 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#29 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#30 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#31 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#32 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#33 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#34 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#35 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#36 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#37 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#38 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#39 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#40 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#41 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#42 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#43 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#44 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
#45 (10.00 fps) exp 98637.00 ag 16.00 dg 1.00
I suspect because I’m using a headless pi 4b and remoting from a windows laptop over my home wifi network, that might be the reason a preview window does not show up. Does rpicam stream a video IP on my home network that I have to use VLC to play, for instance?
please advise what dmesg command you want me to run.
searched google for a few minutes. searched the forum here for a few minutes to try to find out a solution or what is going on.
  1. What help do you need?
How do I get a video window showing me what the camera is seeing? A video window would be helpful for monitoring the focus changes when I get around to installing/using the focus stuff and later the pan/tilt system I will be adding when I get video window and focus stuff figured out.
Thanks for reaching out.
Yes, you’re correct. You can run a command like rpicam-vid to stream the camera and use VLC to play. However, you could observe a noticeable lag with this command.
I highly recommend using a graphical desktop Bookworm OS to get a live preview window with low latency. Otherwise, you can install RealVNC on your PC and use it to log in to your Pi via this software if you don’t want to connect your Pi to a display. In the meantime,
if your Pi is headless (not plugged into a monitor) or not running a graphical desktop, RealVNC Server can still give you graphical remote access using a virtual desktop.
https://help.realvnc.com/hc/en-us/articles/360002249917-RealVNC-Connect-and-Raspberry-Pi#setting-up-your-raspberry-pi-0-0
