Pi Zero 2W Bullseye Arducam 64MP: failed to allocate capture buffers, cannot allocate memory
Hi everyone, I’m stuck trying to get an Arducam 64MP camera working with a Raspberry Pi Zero 2W running Bullseye OS. Whenever I try to capture it just dies with:
Unable to request 1 buffers: Cannot allocate memory
ERROR: *** failed to allocate capture buffers ***
The camera looks detected but nothing actually works. Has anyone hit this before?
Hey, thanks for posting. That error usually points at a CMA / memory allocation problem rather than the camera itself. Could you share:
  1. The exact command you’re running
  2. Your full /boot/config.txt (cat /boot/config.txt)
  3. The output of these two:
cat /proc/meminfo | grep -i cma
vcgencmd get_camera
That’ll tell us how much CMA is actually reserved on the board.
Sure. My environment is a Raspberry Pi Zero 2W, Bullseye OS, Arducam 64MP camera. I amended /boot/config.txt following the instructions I found. Here’s the whole file:
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
#start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d,cma-512
#dtoverlay=imx219
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
#dtoverlay=vc4-fkms-v3d,cma-512
gpu_mem=128
dtoverlay=arducam_64MP
I also tried adding dtoverlay=vc4-kms-v3d,cma-512 but CmaTotal is still 8192kB.
Thanks, that helps. I can see dtoverlay=vc4-kms-v3d,cma-512 sitting in the general section and again under [all], alongside dtoverlay=arducam_64MP, gpu_mem=128, start_x=1 and display_auto_detect=1.
Before I go further, can you paste the raw output of these two commands so we know exactly what the board is reporting?
vcgencmd get_camera
Here you go:
CmaTotal:          8192 kB
CmaFree:           6352 kB
vcgencmd get_camera
supported=1 detected=0, libcamera interfaces=1
So CmaTotal is still 8192kB even after I added cma-512.
Okay, that’s the key detail: CmaTotal is still 8192 kB, which means the cma-512 setting isn’t actually taking effect on your board.
Here’s what’s happening:
  • The Pi Zero 2W can’t use cma-512. On this board the CMA value has to be reduced, i.e. cma-128.
  • Separately, 64MP cameras aren’t really recommended on anything other than a Pi 4. If you do run a 64MP on a non-Pi4 device, you have to lower the resolution.
So please:
  1. Change cma-512 to cma-128 in /boot/config.txt (remove the duplicate/leftover entries so only one vc4-kms-v3d line with cma-128 remains).
  2. Reboot the Pi.
  3. Then try lowering the resolution, e.g.:
libcamera-still -t 5000 --viewfinder-width 1920 --viewfinder-height 1080 --width 1920 --height 1080 -o test.jpg
Give that a shot and let us know what cat /proc/meminfo | grep -i cma reports after the reboot.
Okay, thanks, that makes sense. But I actually want to use this camera with motioneyeos. How do I add the Arducam 64MP to motioneyeos at a lower resolution, less than 1920x1080?
Just to make sure we’re on the same page: we currently don’t have an adaptation for motioneyeos - there’s no official support for it with Arducam cameras, so integration there isn’t something we can help configure.
When you say you want a lower resolution, do you mean you’re already able to use large resolutions on motioneyeos? How exactly are you using it? That’ll help me understand your use case.
Alright. If motioneye isn’t supported by Arducam, then how do I stream video using libcamera over HTTP? Ideally without VLC Player, since VLC is banned in India.
For context, my setup is Arducam on a Raspberry Pi Zero 2W with Bullseye OS, with motioneye OS installed. My plan is to do face recognition using a CNN on a separate Raspberry Pi 3B - images captured by motion detection on the Zero would be sent over to the Pi 3 for the actual recognition.
Got it - so motioneye/motioneyeos isn’t something we support for the Arducam camera, which means you’ll want a different streaming path. For HTTP streaming with libcamera/Arducam (instead of motioneyeos or VLC), have a look at our mjpg-streamer project:
That’s the approach we’d recommend for serving the camera stream over HTTP. If you run into trouble getting it built for the Pi Zero 2W, post the errors here and we can take a look.
