Hello, Hope you are having an amazing day!
I am trying to run two mipi cameras using Pi 4. The default GPIO pin to switch cameras is 7,11 and12 (wiringPi conventoin in manual) repectively goes to 7,19 and 26 pins in Pi(1 to 40 pin convention). Correct me if I am wrong about pin connection.
I have connected an embedded system which takes the default pins along with some other pins. Now I have left with 13,15 and 22 on Pi(1 to 40 pin convention). Is it possible to use these three pins to connect the multicamera adapter and run two cameras without problems?
If not, what is alternative solutions?
Thanks in advance
