Persistent Arducam IMX519 AF camera permission error, no preview on Raspberry Pi 5 (pipeline_base.cpp)
Hi, I’m struggling to get my Arducam IMX519 AF camera to show a preview on my Raspberry Pi 5. Initially I was getting a permission error, which I managed to fix, but now I keep getting pipeline_base.cpp errors at lines 1356 and 1357 and no preview at all. I’ve already tried a different camera cable and the camera itself has no visible damage, so I’m starting to wonder if it’s a hardware fault. I’ve attached a few screenshots of the errors. Has anyone else run into this?
Thanks for the screenshots. Since the permission error is resolved but the preview still fails even with a different cable, the next step is to get a full bug report so we can see what the camera stack is doing. Could you run the bug report tool on the Pi? Steps:
  1. Reboot the device.
  2. wget -O arducam-camera-bug-report https://github.com/ketai-dhr/arducam-camera-bug-report/releases/download/tools/arducam-camera-bug-report
  3. chmod +x ./arducam-camera-bug-report
  4. ./arducam-camera-bug-report
It should create an arducam-bug-report.txt in the current directory. Please attach that file here and I’ll go through the logs to see whether this is software/config related or something on the hardware side.
I ran through those steps exactly — rebooted, downloaded the tool, did chmod +x, and ran it — but the arducam-bug-report.txt it produced is 0KB and completely blank, so I can’t attach anything useful. The terminal still shows the same errors while the tool runs. I’ve attached a screenshot of the terminal output. Any idea why the report would come out empty?
That’s strange. A 0KB report usually means the script ran but wasn’t able to collect the underlying logs. Could you try running it once more and watch the terminal output carefully — especially for any ‘command not found’ or permission-denied messages? Also double-check the size of the generated arducam-bug-report.txt afterwards. We need a non-empty report to move forward with the diagnosis.
I re-ran the tool and checked the file again — it’s still a blank 0KB file, so there’s nothing to attach. The same errors keep appearing in the terminal while it runs. I’ve attached another screenshot of the terminal output. The report just won’t generate.
Thanks for re-running and confirming. To summarize where we are: the original preview failure is still unresolved, and we still don’t have a usable bug report because the tool is producing an empty 0KB file — so we can’t inspect the logs behind the pipeline_base.cpp 1356/1357 errors yet. I’ll look into why the tool returns empty output and get back to you with adjusted steps. For now we can’t tell whether it’s software/config or hardware; we need that valid report first.
