Partial install failure at the Jetson Nano Orin - Jetpack 6.2
  • Where did you get the camera module(s)?
    Online store
  • Model number of the product(s)?
    b016712mp
  • What hardware/platform were you working on?
    Jetson Orin Nano
  • Instructions you have followed. (link/manual/etc.)
    Driver install: Arducam Jetson Camera Quick Start Guide
    Focus test: Motorized Focus Camera Documentation
  • Problems you were having?
    When installing the driver, there were some error messages, but the installation worked:
    ls: cannot access 'nv_imx477.ko.bak': No such file or directory
    mv: cannot stat '/boot/arducam/arducam_csi2.ko': No such file or directory
    During the MIPI Camera focus test using the provided Python code:
    The camera works, but the focus doesn’t change despite trying multiple -i bus options. For reference, only -i 7 works, and no other bus options blink.
  • Log
dvelop@dvelop-desktop:~$ ./install_full.sh -m imx477
./install_full.sh: line 19: warning: command substitution: ignored null byte in input
NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
--2025-02-24 21:54:57--  https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/imx477_links.txt
Resolving github.com (github.com)... 20.200.245.247
Connecting to github.com (github.com)|20.200.245.247|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/120f3fc5-c236-49ba-ae64-58732f168d4d?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=releaseassetproduction%2F20250225%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20250225T025342Z&X-Amz-Expires=300&X-Amz-Signature=daad87a004caef9969402d44615e8c49d3d9b5e310b8121040590652b7eb439a&X-Amz-SignedHeaders=host&response-content-disposition=attachment%3B%20filename%3Dimx477_links.txt&response-content-type=application%2Foctet-stream [following]
--2025-02-24 21:54:57--  https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/120f3fc5-c236-49ba-ae64-58732f168d4d?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=releaseassetproduction%2F20250225%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20250225T025342Z&X-Amz-Expires=300&X-Amz-Signature=daad87a004caef9969402d44615e8c49d3d9b5e310b8121040590652b7eb439a&X-Amz-SignedHeaders=host&response-content-disposition=attachment%3B%20filename%3Dimx477_links.txt&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.110.133, 185.199.109.133, 185.199.111.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.110.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19937 (19K) [application/octet-stream]
Saving to: ‘imx477_links.txt’
imx477_links.txt                         100%[==================================================================================>]  19.47K  --.-KB/s    in 0.001s
2025-02-24 21:54:58 (18.3 MB/s) - ‘imx477_links.txt’ saved [19937/19937]
--2025-02-24 21:54:58--  https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.1-orin-nx/arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/2049c1ab-2df0-4deb-b44f-8038de5387f5?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=releaseassetproduction%2F20250225%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20250225T025343Z&X-Amz-Expires=300&X-Amz-Signature=b97ab95a867447b07fa9c3db13968c9c73c9b417153a8efc3498985c7c4047d3&X-Amz-SignedHeaders=host&response-content-disposition=attachment%3B%20filename%3Darducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb&response-content-type=application%2Foctet-stream [following]
--2025-02-24 21:54:58--  https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/2049c1ab-2df0-4deb-b44f-8038de5387f5?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=releaseassetproduction%2F20250225%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20250225T025343Z&X-Amz-Expires=300&X-Amz-Signature=b97ab95a867447b07fa9c3db13968c9c73c9b417153a8efc3498985c7c4047d3&X-Amz-SignedHeaders=host&response-content-disposition=attachment%3B%20filename%3Darducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.108.133, 185.199.110.133, 185.199.111.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.108.133|:443... connected.
Length: 10525620 (10M) [application/octet-stream]
Saving to: ‘arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb’
arducam-nvidia-l4t-kernel-t234-nx-5.15.1 100%[==================================================================================>]  10.04M  56.5MB/s    in 0.2s
2025-02-24 21:54:59 (56.5 MB/s) - ‘arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb’ saved [10525620/10525620]
(Reading database ... 200111 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.3-20250205154643_arm64_imx477.deb ...
Unpacking arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.3-20250205154643) over (5.15.148-tegra-36.4.3-20250205154643) ...
Setting up arducam-nvidia-l4t-kernel (5.15.148-tegra-36.4.3-20250205154643) ...
reboot now?(y/n):
  • What help do you need?
    Is my installation correct?
    Why is the focus not changing?
The installation procedure is correct.
You can refer to the following thread.
great. thanks!
what is the i2c bus for jetson nano orin? in the code, there is only A02, B01, Jetson Savier NX (for A02 is 6, for B01 is 7 or 8, for Jetson Xavier NX it is 9 and 10.)
You can try the i2c bus 1 or 9 or 10 on Jetson Orin Nano.
thx. I got the error message when using FocusExample.py
camera was ON, but when I press the “t”, error happens. i tried -i 9, 10 (for cam0, cam1) both, but it was the same
CONSUMER: Waiting until producer is connected…
GST_ARGUS: 4032 x 3040 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59.999999
[ WARN:[email protected]] global cap_gstreamer.cpp:1728 open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
File “/home/dvelop/MIPI_Camera/Jetson/JetsonNano_PTZ/FocuserExample.py”, line 239, in
main()
File “/home/dvelop/MIPI_Camera/Jetson/JetsonNano_PTZ/FocuserExample.py”, line 231, in main
curses.wrapper(draw_menu, camera, args.i2c_bus)
File “/usr/lib/python3.10/curses/init.py”, line 94, in wrapper
return func(stdscr, *args, **kwds)
File “/home/dvelop/MIPI_Camera/Jetson/JetsonNano_PTZ/FocuserExample.py”, line 206, in draw_menu
parseKey(k,focuser,auto_focus,camera)
File “/home/dvelop/MIPI_Camera/Jetson/JetsonNano_PTZ/FocuserExample.py”, line 152, in parseKey
focuser.set(Focuser.OPT_MODE,focuser.get(Focuser.OPT_MODE)^0x0001)
File “/home/dvelop/MIPI_Camera/Jetson/JetsonNano_PTZ/Focuser.py”, line 166, in set
self.write(self.CHIP_I2C_ADDR,info[“REG_ADDR”],value)
File “/home/dvelop/MIPI_Camera/Jetson/JetsonNano_PTZ/Focuser.py”, line 85, in write
return self.bus.write_word_data(chip_addr,reg_addr,value)
OSError: [Errno 121] Remote I/O error
FATAL: exception not rethrown
