I’ve been using your old black camera pan tilt with a separate 16 servos control board. I’ve purchased 2 new ones of the new model (not yet with me), those with its 2 servos control square board.
This is what I’m trying to get: the pan-tilt system will be fixed in a point for several days. Once in place I’ll pan and tilt the camera from software to a desired position that must remain fixed forever.
The problem I have with the present system (the old with 16 servos control board) is that every time the system is rebooted the position of the camera shifts a bit. I’ve tried in the past with a non latching relay to cut the current to the control board but it worked randomly.
So, what I’m asking you is if from your software or another one way is it possible to cut the current to the new 2 servos control board to avoid further camera movement
Thank you
