Pan and Tilt Servos
Do the Pan Tilt motors require an external power source? If so is there a spec on voltage and amp draw?
The motor needs additional power supply, the specific power supply requirements should be determined according to the parameters of the motor you use.
I purchased the Arducam ptz kit which included the motors so I would expect to be able to get those power requirements from this website. Is that not the case?
Please attach me your servo’s image and I will help you ensure the servo type and tell you the power requirements.
Bin,
I ended up finding a cut sheet on the motors. The model # is DS3115. They are made by https://www.dsservo.com/
I was able to connect the power and ground to GPIO-2 and GPIO-14 respectively on my Raspberry PI-4. Everything is working great! The data sheet indicates that the motors require 4.8vdc to 6.8vdc and run around 4-5ma.
Thanks!
Aaron
Great to hear that. Let me know if you need more help.
