robot shop
https://www.robotshop.com/de/de/arducam-ov9281-1mp-mono-global-shutter-mipi-kamera-raspberry-pi.html
Raspberry pi CM 4 IO board
https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera/#software-setup
Never worked
so I just got this camera module: https://www.arducam.com/product/arducam … pberry-pi/ from Arducam.
And after that I connected the module with the comput module 4 IO board through the CAM0 CSI-2 interface.
And I fitted the 2 jumpers on J6 for the I2C communication for CAM0.
Next, I added “dtoverlay=ov9281” to the config file, to enable the camera module.
Finally I booted the pi and checked the loaded driver with “modinfo ov9281”, and it is the one located at “/lib/modules/5.10.46-v7l+/kernel/drivers/media/i2c/ov9281.ko”. Everything as expected so far.
But checking the dmesg I see the following error:
[ 7.098148] ov9281 10-0060: Unexpected sensor id(d0fc2400), ret(-5)
And I also have no device at /dev/video0.
As you can see above, my kernel version is 5.10.46-v7l+
Checking the driver here: https://github.com/raspberrypi/linux/blob/rpi-5.10.y/drivers/media/i2c/ov9281.c
I see that this rpi driver only supports 2 lanes MIPI CSI-2, but on the board only 1 data lane is routed from the camera board to the raspberry pi. So it doesn’t surprise me that this driver isn’t working. But since the Arducam website says that it has official RaspberryPi support, it strikes me to see that it’s not easy to find.
I want to use the kernel mode driver only, not the userspace one. So could you please provide me a working driver ?
through this forum
