Robotshop
UC-599
Raspberry Pi 4B 4GB w/ 32GB Sanddisk SD Card using HDMI0 to a monitor at 1920*1080
I first followed the instructions here in the quick start guide: https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera/, and then the one here https://github.com/ArduCAM/MIPI_Camera/tree/master/RPI
No
I have tried on a fresh install of raspberry pi os still doesn’t work.
When i did this i first followed the tutorial here, and I managed to see a preview of the camera using Yavta, but the image was extremely dark. After this I followed the tutorial on github, including the section marked "For PI 4 Platform, as well as every other step. When i run ./arducamstill, i get the following error:
After this the program gets stuck and I have to manually close the termina; (doesn’t respond to ctrl-c). I note that it stops before the example screenshots on the Github tutorial says ‘can’t open the file’, perhaps it tries to open a file and cannot terminate that process? Just a guess.
Interestingly, the second time I tried it I forgot to do the quickstart guide and when I ran arducamstill it got further to the line where it said “Start Preview”, but still got no preview and it did not write any images. When i then put ‘dtoverlay=ov9281’ into config.txt it went back to how it was in that screenshot above.
I have tried rebooting, giving 512mb of GPU memory etc. I really can’t figure out what’s the problem. I’ve checked I have it connected to the PI correctly which I believe i do.
Suggestions for fixes
