OV9281 MIPI module - where are the V4L2 drivers?
Pi0W and Pi4B
https://www.arducam.com/product/arducam-ov9281-1mp-mono-global-shutter-mipi-camera-with-130degree-850nm-only-m12-mount-for-raspberry-pi/ describes the availability of a V4L2 driver for this module. My question is simple: Where can one acquire the driver? There is nothing obvious on Github.
Many thanks
Thanks for your business. Using Arducam ov9281 is very easy, just open the /boot/config.txt and add dtoverlay=ov9281 then reboot your system. You can get the detail user guide here https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera/
Many thanks. That works as expected.
One more question: Does raw mode using the Arducam MIPI library work when the overlay is active?
You are welcome.
If using Arducam MIPI_Camera driver. you can’t enable the dtoverlay=ov9281, just comment it and reboot.
