Arducam OV9281 1MP Global Shutter USB Camera Evaluation Kit - 1/4-inch Monochrome M12 Camera Module with USB3 Camera Shield and MIPI Adapter Board -
OV9281 1MP Global Shutter without USB Shield -
Jetson Nano Developer Kit B-01 with Jetpack 4.6
#R32 (release), REVISION: 6.1, GCID: 27863751, BOARD:t210ref, EABI: aarch64, DATE: Mon Jul 26 19:20:30 UTC 2021 -
1. Camera Driver Installation - Arducam -
After running install_full.sh the expected device I should see is /dev/videoX.
/dev/videoX is not in the folder and not even able to run using vlc player. -
Sending snippet of dmesg.
[ 1.298744] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.316579] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.316582] Extcon AUX1(HDMI) disable
[ 1.322935] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 1.323153] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 1.323369] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 1.323444] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 1.323449] arducam-csi2 7-000c: probe failed
[ 1.323482] arducam-csi2 7-000c: Failed to setup board.
[ 1.347064] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 1.347283] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 1.347494] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 1.347567] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 1.347574] arducam-csi2 8-000c: probe failed
[ 1.347605] arducam-csi2 8-000c: Failed to setup board.
[ 1.348705] max77620-power max77620-power: Event recorder REG_NVERC : 0x0 -
Tried to resinstall the Jetpack but no luck.
Not understanding how to troubleshoot -
Need proper steps to install drivers in a jetpack. (Or any required step)
Steps to see the stream on VLC player and as a webcam
Hi @atulghumade
You are using the wrong driver. For USB Camera Shield, please refer to:
@wong
Thanks for responding.
I m not using USB shield. I m directly using MIPI interface.
The product you purchased cannot be used directly on Jetson.
