OV9281 MIPI Camer a Module with RPI3 problem
I tried reboot and deinstalled and reinstalled
Arducam OV9281 MIPI 1MP Monochrome Global Shutter Camera
Raspberry PI 3B+
https://www.arducam.com/docs/cameras-for-raspberry-pi/mipi-camera-modules/camera-userland-driver-sdk-and-examples/
works with yavta example as described
But after installing the SDK and running $ ./arducamstill -t 0 -m 1 -awb 1 -ae 1
the response is:
Open camera…
Hardware platform: a020d3
Found sensor ov9281 at address 60
mode: 0, width: 1280, height: 800, pixelformat: GREY, desc: (null)
mode: 1, width: 1280, height: 720, pixelformat: GREY, desc: (null)
mode: 2, width: 640, height: 400, pixelformat: GREY, desc: (null)
mode: 3, width: 320, height: 200, pixelformat: GREY, desc: (null)
mode: 4, width: 160, height: 100, pixelformat: GREY, desc: (null)
mode: 5, width: 1280, height: 800, pixelformat: GREY, desc: Used for ov9281 2lans raw8
mode: 6, width: 1280, height: 800, pixelformat: Y10P, desc: Used for ov9281 2lans raw10
mode: 7, width: 2560, height: 800, pixelformat: Y10P, desc: Used for synchronized stereo camera HAT 1280x8002
mode: 8, width: 2560, height: 720, pixelformat: Y10P, desc: Used for synchronized stereo camera HAT 2560x720
2
mode: 9, width: 1280, height: 400, pixelformat: Y10P, desc: Used for synchronized stereo camera HAT 640x4802
mode: 10, width: 640, height: 200, pixelformat: Y10P, desc: Used for synchronized stereo camera HAT 320x200
2
mode: 11, width: 320, height: 100, pixelformat: Y10P, desc: Used for synchronized stereo camera HAT 160x1002
mode: 12, width: 2560, height: 800, pixelformat: GREY, desc: ov9281 1lane raw8 1280x800
2 for synchronized stereo camera HAT
mode: 13, width: 1280, height: 800, pixelformat: GREY, desc: Used for ov9281 1lane raw8 1280x800 external trigger mode
mode: 14, width: 1280, height: 720, pixelformat: GREY, desc: Used for ov9281 1lane raw8 1280x720 external trigger mode
mode: 15, width: 640, height: 400, pixelformat: GREY, desc: Used for ov9281 1lane raw8 640x400 external trigger mode
mode: 16, width: 320, height: 200, pixelformat: GREY, desc: Used for ov9281 1lane raw8 320x200 external trigger mode
mode: 17, width: 1280, height: 800, pixelformat: GREY, desc: Used for ov9281 2lanes raw8 1280x800 external trigger mode
mode: 18, width: 1280, height: 800, pixelformat: Y10P, desc: Used for ov9281 2lanes raw10 1280x800 external trigger mode
mode: 19, width: 1280, height: 720, pixelformat: GREY, desc: Used for ov9281 2lanes raw8 1280x720 external trigger mode
mode: 20, width: 640, height: 400, pixelformat: GREY, desc: Used for ov9281 2lanes raw8 640x400 external trigger mode
mode: 21, width: 320, height: 200, pixelformat: GREY, desc: Used for ov9281 2lanes raw8 320x200 external trigger mode
index: 0, CID: 0x00980914, desc: V4L2_CID_HFLIP, min: 0, max: 1, default: 0, current: 0
index: 1, CID: 0x00980915, desc: V4L2_CID_VFLIP, min: 0, max: 1, default: 0, current: 0
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 681, current: 32
index: 3, CID: 0x00980913, desc: V4L2_CID_GAIN, min: 0, max: 15, default: 1, current: 8
index: 4, CID: 0x00981901, desc: V4L2_CID_ARDUCAM_EXT_TRI, min: 0, max: 1, default: 0, current: 0
and it does not list the current mode framerate .etc
If I run the same command once more (after exiting with ^C) the response is :
pi@raspberrypi:~/MIPI_Camera/RPI $ ./arducamstill -t 0 -m 1 -awb 1 -ae 1
Open camera…
and the program stalls. All other example programs show the same behavior.
Any help is much appreciated.
yes
Don’t worry and I will try my best to help. Using MIPI_Camera driver, you should open the /boot/config.txt file and comment “dtoverlay = ov9281” then reboot. Both the two driver can’t work together.
Thanks a lot!
I am able to run the c-based example codes now. However, there still seems to be a problem with the python code:
it looks as if the v4l2 library does not support python 3? Is this correct? The capture.py example runs under python 2 but not under python3?
Thanks again,
Great to hear you have run the C code normal. Yes, about the pyth0n code, you are right, it seems the v4l2 python library is used for python2 instead of python3.
