Arducam OV9281 1MP Global Shutter USB Camera Evaluation Kit - 1/4-inch Monochrome M12 Camera Module with USB3 Camera Shield and MIPI Adapter Board -
OV9281 1MP Global Shutter with USB3.0 Camera Shield -
X86 Architecture, Ubuntu 20.4 -
https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield/tree/master/Linux_x86/Python/Streaming_demo -
I tried to use multiple Config files for this part but I m getting following error:
USB_CAMERA_DATA_LEN_ERROR RECEIVE_LENGTH:750776
Error capture image, rtn_val = 65316 -
Not understanding how to troubleshoot -
Need proper steps to install it in Ubuntu 20.04 X86 Platform
Which Configuration file I need to use
What modifications are needed in Co
nfig file
Hi @atulghumade
You should use the configuration in this directory:
Other possibilities:
- Connecting this camera to the USB2.0 port can also cause this problem.
- If this error only occurs once or twice at the beginning, then this is normal.
